Results 1 to 8 of 8
February 19th, 2008 10:03 PM #1
Hi guyz! This is my first post here... tried to look for similar treads pero wala ako makita. Anyway, here's my quiry to all you computer wizards out there...
I overheard kc na pwd k daw mag-install uli ng software na expired na un trial period so as long as completely nabura ung reord nya sa system... Something to do with the system registry (registry editor)... Totoo po ba to? useful to pag wala kang pang pambili ng registration key!
If true, paturo naman kung pano gwin....
Tnx!!!
February 19th, 2008 10:45 PM #2
If I'm reading this right, you want to keep using a trial version of software and trick it into continuing to work past its expiration date........ It could be in the registry and then again, it could be somewhere else.
I remember doing this with WindowBlinds back when I had Win2k Pro. I just kept resetting the date each day both in the bios and Win2k itself.It worked.
Add: I tried it with other software. But, it's not really worth the effort. Plus, their manufacturers have gotten smart. Resetting the date doesn't work anymore.Last edited by Jun aka Pekto; February 19th, 2008 at 10:51 PM.
February 20th, 2008 01:34 AM #3
used to run this program that opened the .exe file of the trial software. worked for a while until the manufacturers, like jun said, got smart.
but, IMO, I think its it easier if you look for a crack online rather than playing with your sys reg.
and to answer your query on complete uninstalls, i use REVO Uninstaller. libre pa.
Driver/PasaHERO
- 1,310
February 20th, 2008 02:46 AM #4it is not always found in the registry, it could be somewhere else for all we know. If you liked the product and want to keep it, why don't you get a full version/licensed one
February 20th, 2008 11:27 AM #5
Ingat nga lang sa pardodownload ng mga cracked or keygenerators, meron kasing mga ganyan na infected ng malware (Russian cracked/keygens tend to have more of these basing upon my experience.)
February 20th, 2008 08:29 PM #6
there is a proggy called Nolimit Date Faker. I used to use this in a cracked program but only runs not more than year 2006.
however, it's better to look for the crack instead. and yep, not all are stored in the .reg
sometimes, keygen is detected as spyware by AVG. but it is really harmless.
February 21st, 2008 01:28 PM #7
Tnx for the inputs Guyz!!!
Wla kc me makita crack saka hindi lhat ng download sites sa Pina s meron d2 e... Mahigpit portal nila...D2 me KSA now... Active Barcode un program... sabi ko sa boss ko e magpurchase na lang e ang kulit, maghanap n lang daw ako sa net ng freeware...
Hay mga arabo nga naman...
Driver/PasaHERO
- 1,310
In that case, I think NCAP is something that they have privatized.
SC (temporarily) stops NCAP
