yeah marami syang wires.
You'd see yung malaking block (either 20pin or 24pin). may black and green dun. yun yun kailangan i-short (or lagyan ng switch but for testing, use a paper clip).
The yellow is the +12v and the blue is -12v. I'm not sure though what's the difference between using the -12v and ground (black) for the HID. As for the harddisks (which uses 12v and 5v), it uses the +12v and the ground.
ATX power connector;
Tapos dun sa power para sa harddisk (yung apat ang wire).
Ang +12v yung yellow wire. Negative would be the black. Red is +5V
