Results 1 to 3 of 3
    Improve System stability
    Key: HEKY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\
    Create a new DWORD value called AlwaysUnloadDll and set its value to 1.
    Speed up Explorer
    Key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\FileSystem
    Create the DWORD value NtfsDisableLastAccessUpdate and set it to equal 1.
    Speed up the start menu
    Key: HKEY_CURRENT_USER\Control Panel\Desktop\MenuShowDelay
    Double-click on MenuShowDelay and look at the Value Data. Set it to 100.(default=150)
    Tweak The Prefetch
    1. Run "Regedit"
    2. Goto [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Session Manager\Memory Management\PrefetchParameters\EnablePrefetcher]
    3. Set the value to either 0-Disable, 1-App launch prefetch, 2-Boot Prefetch, 3-Both ("3" is recommended).
    4. Reboot.
    It will decrease the boot time but double and increase the performance of your XP.
    __________________________
    Just copied this from another forum, but I do not know how to do this can anyone here help me...BTW, do these tweaks work? TIA
    Jun 2006
    may kulang. make a back up of your registry first. madaming guide sa net. tweak at your own risk.
    Quote Originally Posted by Negus View Post
    yup, that's true. You can either successfully tweak it OR you can add more problems, worse it will crash.
Help with these tweaks...
