Results 1 to 10 of 22
August 22nd, 2024 09:33 PM #1
August 23rd, 2024 11:45 AM #2
Before the pandemic and when my phone was still locked, I use services like these when traveling abroad. I just order online ahead of my arrival date and pickup the hotspot at the airport on my arrival. On my flight home, I just dropped it off at the same kiosk in the airport. You just need to arrive early as the kiosk is often located nearer to the arrival gates.
klook.com
kkday.com
Later on, I was ordering prepaid SIM cards which I still have to pickup at the airport, but just throw away after the trip.
Now, eSIMs are king. Nothing to pickup or return. Just order online, install it, and it's ready to use once you land.
Tsikot Member Rank 3
- Nov 2002
- 2,000
August 28th, 2024 02:29 PM #3you can download Apps like Airalo or Ubigi.
They will activate an esim fro you depending on what country you are in.
no need to go to any stores to buy esim.
i have used them and it works well naman.
August 28th, 2024 05:52 PM #4
- Nov 2024
- 20
November 14th, 2024 04:17 PM #5If you're deciding between SmartBro Pocket WiFi and Globe Tattoo MyFi, it really depends on the network coverage in your area. If Globe has strong coverage where you are, then Globe Tattoo MyFi could be a great option. You’ll need a Globe SIM for it, and if you haven’t registered your SIM yet, you can check out globsimregistration.ph to get it set up quickly. Both options are portable and can give you good internet access on the go!
Toyota's Land Cruiser 3�� Finally Gets a Hybrid Version with the 2�26 Model — The Most Powerful Yet...
2021 Toyota Land Cruiser LC300
