Results 1 to 11 of 11
    Apr 2006
    Ano po ba magandang gawin para maiupgrade yung pc namin like video card for gaming purposes. Anu-ano po kailangang palitan. Ang sarap kasing maglaro e hehe...
    eto yung current pc namin.
    Dell Optiplex GX260
    Windows XP Professional SP2
    Pentium(R) 4 CPU 2.40GHz Intel(R)
    512 MB of ram
    80 HDD
    Intel(R) Extreme graphics
    Physical Memory: 509 MB
    Min. Graphics Memory: 1 MB
    Max. Graphics Memory: 64 MB
    dami pong salamat....
    Jun 2006
    Since that's a P4, i'd assume AGP 8x ang gamit nyang videoport, just get the fastest AGP card available, i think it's the 7900 series of Nvidia
    upgrade ram to DDr400 1GB dual channel (2 same sticks). better if 2GB since RAM now is very cheap.
    upgrade HD to SATA2, 7200rpm. 10,000rpm SATA2 is best but a bit expensive.
    YOu can upgrade the processor to higher speed also.
    If you want something better, build a completely new system based on the Intel QuadCore series.
    Apr 2006
    thank you very much sir ang laking tulong nito
    Jun 2007
    upgrade mo muna memory to 1 gig
    kung mabagal parin upgrade video card ung palit ok na ok
    Apr 2006
    magkano po kaya magagastos kung dyan sa pinas bibilin lahat ng papalitan?
    check out this site: pcx.com.ph. i buy my stuff from them and while i'm aware that there are cheaper options out there, this store has never let me down. yup, go with the memory upgrade first but i think you'd see a greater improvement if you install a decent agp video card. if you're going for a cpu upgrade, i think it would be better to upgrade your mobo as well to be able to use the newer core 2 duos or amds.
    Aug 2006
    Quote Originally Posted by lhandzs View Post
    Dell Optiplex GX260
    512 MB of ram
    80 HDD
    what chassis is your optiplex built on? (full desktop, mini tower or small form factor?) if you have the small form factor, you're unfortunately out of luck. you can't upgrade.
    kung full desktop or mini tower, have to replace the aging psu first (a new 380w coolermaster psu costs around 1.6k). the optiplex series (released mid 2002) come with either a 250 or a 300w psu. its definitely not going to be enough to power a graphics card upgrade.
    also, the most decent agp gaming cards (7900gs - around 6k) require a separate 6 pin power connector which only newer psus have.
    finally, a 512 stick of ddr400 ram costs around 1.3k and a stick of 1 gig ram costs around 3k.
    Aug 2005
    if im correct the optiplex gx260 is a small form factor. yung manipis bro.. so in otherwords.. di kasya ang mga full cards sa tower mo. limited masyado ang options mo jan (usually RAM upgrades, USB peripherals, HDD, optical drive upgrades lang).
    Instead of trying to make it work as a gaming system its better to buy a another tower.. kahit clone system lang.
    Apr 2006
    yung manipis lang siya at nakahiga. malamang bago na lang ipon muna. salamat sa mga tulong mga sir
    Palitan mo yung "Intel(R) Extreme graphics " ng mas malufet. GeForce or ATi radeon
    Apr 2006
    kung pwede sana kaya lang hindi raw yata pwede kasi manipis lang daw yung chassis ng pc ko. anong series kaya sa Ge force or ATI radeon ang pwede. o kaya talgang kailangan ko na talaga siguro ng bago. thanks sa reply sir
help pls.
