Results 11 to 20 of 31
September 24th, 2007 06:00 PM #11
happened to me once, buti naka partition HD ko and all my data was on drive D:, C: only had the OS and the programs kaya ok lang reinstall.
pero pag orig XP pwede mo restore lang without damaging the data, aayusin nya OS lang.
nurse on wheels
- Dec 2006
- 392
September 24th, 2007 09:10 PM #12you can do a repair installation. your files won't be damaged. did it a lot of times. you may, however, want to do a fresh install after backing up your files.
September 25th, 2007 12:25 AM #13
Tama si moe, you could try the repair option and if still doesn't work, sadly you have to reformat your PC..
This is the reason why I place my important files on the other partitioned disks so that if i need to reformat it, it wont get deleted.
It's also impt to back them up in a CD...you'll never know...
September 25th, 2007 12:51 AM #14
yup, repair option lang yan, no need to reformat... basta may cd ka magagamit mo yung repair option... pero hindi yung first repair option ha, ung second repair option... check this site, it will really help you a lot!!! Promise, it even has picture screenshots to guide you through http://www.informationweek.com/share...leID=189400897 Let us know if what happened sa pc mo ha!
September 26th, 2007 11:16 AM #15
waaaaaaaaaah... yap my xp cd has a repair option but it is askin for the administrator password! i didn't remember i put a password. i tried several times but after 3 incorrect attempts it restarts.
guys any other options?
or anyone who knows how to retrieve the administrator password??
nurse on wheels
- Dec 2006
- 392
September 26th, 2007 11:43 AM #16hmmmm. were you the one who installed the previous copy of windows? anyways, try the 4 zero combo or 12345 or 1234 or leave it blank. if all else fails remove your harddisk, and attach it to another pc, copy/backup your files then do a clean install.
- Dec 2006
- 40
September 26th, 2007 11:58 AM #17I make it a habit when installing an OS, I place my data on a different partition separate from the system files. That way, when the system goes south, I can reinstall the OS without affecting my data files.
September 26th, 2007 12:45 PM #18
Rule of Thumb:
Always have separate partitions for System and your data para in cases of System failures, intact pa din mga files/data mo.
If you have another PC, slave mo muna and copy all the data you need. Then saka mo reformat/reinstall para ma-resolve yung problem.
September 26th, 2007 01:36 PM #19
how to slave what do you min with that? we have tried to put it on another pc, but when i try to copy the documents and settings folder " cannot copy make sure the disk is not full or write protected" (w/c is not), when i try to click the folder to open it " access denied appears...
Suzuki JIMNY [merged threads]
