just bought a laptop and its wifi is 80211 n. the sales man said that in order to maximize wifi, i should get an N router.
he also added its ok to use a B or G router, but the wifi will not be maximized.
just want to know if this is true.
thanks
thanks
Yes, it's true.
The thing to consider is how you're going to use the connection. If it's only for Internet access, you won't need N since your ISP connection will never reach those speeds. But if you have a home LAN and do lots of large file transfers or stream media from a file server, you'll thank yourself for the extra boost.
Everything sir Yoda said + if your house is so big, you might need the larger coverage of N.
As for me, I upgraded to N just for kicks but now that I have a new house built near my parents', I get to use the advantage of N because I can still share my internet, files and printers with them esp since we're divided by many layers of steel reinforced concrete and I-beams which creates crazy amounts of interference.
Thanks for the replies.
so if its basic use i can just buy the b/g type. but it would be better to invest in an N type.
t![]()
Price is another factor. If the diff isn't too much, N would be a good investment. Not sure how it is these days, dati malaki talaga.
Hi guys..Ask ko lang po kung paano lagyan ng password itong router namin? Even though sakto lang ang range niya for the size of our house, I still want to make sure.. Tagal na nito eh di ko talaga alam kung paano lagyan ng PW
got an N router already from premium logic megamall. brand is tplink.
ok nman so far.
ride on lang po ako dito.. i hope it's okay.. kung hindi naman.. i suppose transferring to a new thread is okay din...
i used to use a linksys router sa bahay... okay naman... problem ko lang is kapag may isang iphone na nakakabit, other iphones or mac have a hard time connecting sa wifi...
so i tested to use a buffalo wifi router (yung may abang na USB for external disk).... so far the iphone / mac issues have been addressed.. ang weird is, i also have a lenovo laptop (hindi yung thinkpad series, the other one)... hindi maka connect... laging wrong password daw (wpa-tkip) kahit sigurado na ako sa password na tama.. hindi pa rin tnatanggap... i tried connecting through wps.. fail din.... ano kaya pwede gawin?
You can try disabling the password totally and try testing if you can connect.
had also happened to my D-link serries N. yung acer laptop ko pwede but not my daughter's toshiba and wifi phone. ni-reset ko with NO password, hayun ok na lahat. di ko na nilagyan ulit ng password dahil wala naman akong alam na may wifi capable sa mga neighbors namin.
to answer TS question... very significant ang difference nila in terms of coverage. yung sa akin pwede ko pang gamitin sa labas ng bahay with 3-bars sa connection indicator.
In my case, I use my N router without password but I enabled MAC number security as alternative to WPA security which is having problems.
kung walang WPA password but with mac filter... meaning i have to register manually yung mga mac addresses ng mga machines that i allow to use the wifi at home before they can use it?
hindi kaya uubra na tipong AND/OR? like for machines i'm having trouble with connecting through WPA-TKIP, i'll force the MAC FILTER to take over, while for those that have the right password, hindi na kailangan setup yung MAC FILTER?
got relatives kasi who visit often during the day (habang wala ako sa bahay) and they use wifi ...
The MAC filter cannot be used in a "and/or" with the WPA. So either you get the WPA working or use the MAC filter. IF relatives visit often, then you should input their computer's MAC number into your router's MAC list.
If not, you might have to fall back to WEP security. Downside, WEP security means you cannot use "N" protocol and speed.
wala din password yung router ko but i use the MAC FILTER the other way around.
minsan kasi, madami friends ng anak ko ang nasa bahay using wifi. so instead of inputting their mac #, i block unwanted connections na lang using a MAC scanner..
so far, 4 pa lang yata ang nablock ko since last year..
