Hope it won't end up a all show and no substance effort like the Educational Plan Fiasco
Sen. TG Guingona Receives Complaint versus Fair Use Policy![]()
"97% of users don't use 1GB/day or 3GB/month" - Ibig sabihin 97% ng subscribers nila ay naloko lang nila. Nagsubscribe pa sa HSDPA+ e hindi naman pala nagagamit to the fullest. Might as well use 3G.
Globe was very stupid to not do proper research before making this claim. It is easy to deduce that these mobile users will start using the connection at home also. I mean c'mon, LTE unlimited on a mobile device? Eh di gagamitin ko na rin sa bahay diba?
Again, nothing wrong with the FUP, but everything wrong with Globe's initial claim and then backtracking after realizing the truth about consumer behaviour.
Globe's market research team was caught flat footed on this one.
Correct me if I'm wrong but data speed is affected not by bandwidth hog as the call it. But rather by over subscription in a particular area/tower.
Sent from my iPad using Tsikot Car Forums
#retzing
Yep that's correct. The common term used when speed is throttled down is due to "congestion" to a certain tower. The thing with mobile internet is there is always this "bandwidth" issue pag marami kang ka-share sa area/location. Not sure if Globe uses the same system but from my previous work, you can be using more than your alloted data allowance and still have fast speeds if you are on a location na wala kang masyadong ka-share. Problem sa Philippines is everyone is using it since we are a mobile/smartphone-using country and internet-user to the max pa. Tapos yung mga ibang mobile network for sure share the same LTE towers with Globe so talagang patay na. Mahaba-habang problema to mga ka-tsikot I guarantee you.![]()
errr... is this legal?
or, is this covered under "conditions subject to change without prior notice"...?
stupid question: apektado din ba nito mga dsl globe users sa bahay?
Sent using Pera Padala
Globe broadband also has cap. had it disconnected na. for the same monthly, now using skybroadband but 1.5X times faster assuming maximum "theoretical" speed
May cap ang globe dsl users, but not as bad as the mobile fup. Its 3gb a day for 1mbps, 5gb a day for 2mbps, 7gb a day for 3mbps. If u reach the cap, bandwidth / 2.
Middle finger to Globe's FUP :hammer:
Mukhang ibababa ko nalang sa 599mo ung subscription ko sa kanila. Sayang lang binabayad di ko na magagamit ng maayos. 50mb nalang pwede na pang tsikot forums sa phone
Posted via Tsikot Mobile App
