Results 11 to 20 of 40
August 29th, 2007 03:14 PM #11
I just borrowed the E90 to see if I need it. Returned it after a week. Realized, it can't do what i want but it's good for mobile documents, mobile surfing etc.
there are three N95s at home. It's fine, fancy because it's really light despite its size and form. I just want the GPS thing in it instead of bringing another device like Garmin whenever we go roadtripping. but no success at the moment with the GPS. I've been using the N-series ever since the N70 and i really haven't used much of the features. heheLast edited by Horsepower; August 29th, 2007 at 03:18 PM.
- Oct 2004
- 285
August 29th, 2007 03:30 PM #12Thanks HP...I'm still undecided, seems that both are very good phones and each one has its good and bad points....ooh this is a hard decision....
- Oct 2004
- 285
August 29th, 2007 04:15 PM #14
August 29th, 2007 06:19 PM #15
When you view the satellite info, do you see white bars beside the satellite #'s? The bars indicate the relative signal strength, but GPS receivers need to lock on these signals first. This delay is called Time-To-Fix (TTF). When your N95 gets to lock on the signal, the bars should turn black.
The voice-guided navi feature is an additional service - you pay extra. Without it, you can still use the GPS for positioning/searching on the supplied map, and even the route planner (directions in text form). There's no speed indicator, though.
August 29th, 2007 06:43 PM #16
So the speed in the position tab won't work?
I see so i have to wait for the bars to turn black.
Thanks a lot Straightsix, will try it again.
BTW, Is it normal that i can't detect satellite signal inside a relatively small building (about 6 floors)?
August 29th, 2007 07:59 PM #17
Magkaiba yata software natin, hehe. The only options on my phone's position tab are Send Location, Save Location and Search Nearby. Or maybe I just missed it.
The N95's receiver is one of the things I don't like with its GPS feature. The TTF and sensitivity aren't good. TTF is comparable to the (standalone) Navman I bought more than 3 years ago. It loses the satfix even when I'm only besides the window inside the house ... sometimes even when it's placed in the middle of the car's cabin (on the console by the handbrake). So yes, your problem is normal. The TTF from a cold start is so long, it averages more than 2 minutes on my N95 out in the open.
BTW, how's the Manila map? Does it still include only the major roads?
- Oct 2004
- 285
August 29th, 2007 11:29 PM #20
try checking out the Nokia 6110 Navigator. It also sports a GPS navigation system (better than the one found in the N95). It's also cheaper than the N95.
in my opinion, ang dapat na yearly emissions testing ay ang mga PU vehicles. we regularly espy a...
LTO accredited emission testing centers
