Results 1 to 16 of 16
Threaded View
    A few decades ago, the gas turbine car was an interesting idea. Basically it was a jet engine modified to drive the car's wheels.
    (And to those wondering, yes I have been watching a bit too much of the History Channel & Turbo on cable.)
    I was wondering if it can be revived to a more modern adaptation? The main drawback of the old turbine car was the slow acceleration. The positive sides of the engine were that it was smooth (no vibration) and it would burn anything as fuel as along as the liquid will burn.
    I was thinking to connect the turbine engine to a generator so there is no direct mechanical drive from the engine to the wheels. The wheels would be connected to electric motors. There would also be some batteries onboard so the engine can be shut-down during short-trips. Since there is no mechanical link to the wheels, the turbine engine can be operated at it's most efficient rpm to maximize power at minimum fuel consumption and emissions.
    Given the turbine engine can burn anything, the owner would have the choice of whatever fuels he wishes to use like gasoline, diesel, kerosene, paint thinner and even vodka.
    What do you think?
Gas turbine engine for car use?
