Results 1 to 3 of 3
- Feb 2008
- 898
September 19th, 2014 06:12 AM #1I am building a duplex bachelor's pad and the set-up is from the flooring up to the base of the windows would be hollow blocks and after that I am using hardiflex (cement board) including the ceiling. I am now about in install the roof and my question is should it be necessary to install an insulation foam as protection from the heat of the sun? would the thinnest 5mm one-sided foam be enough?
September 19th, 2014 06:45 AM #2
September 19th, 2014 08:36 AM #3
Polystyrene foam is a good heat insulation but not so good sound insulation. You should try Owens Corning noise batt. R-value is high and so is the noise reduction
Posted through phlpost.gov.ph
the triumph of man over... man!, using the crudest of implements (by modern standards).
Traffic!
