Results 1 to 14 of 14
    Jul 2012
    Anyone experienced this? My original lightning cable charger for my son's ipad mini just gave up on me and had it replaced under warranty. 2-3 weeks waiting time so bumili muna ako ng class A cable. For the first week gumagana naman, but then bigla na lang hindi na nagchcharge yung ipad. Saying something like 'cable is not authentic and may not work properly'. I just don't know kung dahil ba nagupdate ako ng latest version ng OS or what. Similar thing happened to my wife's IP5, nung una gumagana, then after a while same na, not accepting the fake charger. Difference is hindi siya nagupdate.
    Jan 2009
    If you're on iOS 7.x, most third-party cables will simply not work. I say most because, you can still find non-Apple Lightning cables that works, but it's typically far in between.
    If your iOS is older than v7, the cable may have simply died.
    See here: iOS 7 Killed Off Some Unlicensed Lightning Cables, But Here's A Fix That Might Work For You | Cult of Mac
    Mar 2012
    Sayang di na available yang tweak n yan. Useful sana.
    Posted using iPhone 8
    Sep 2009
    Try not using your Ipad while charging it. Ilang beses na ako bumili ng 8 pin cable sa CDR King and lagi lang nasisira. Aince then, pinagbawal ko na gamitin yung Ipad habang naka charge.
    Posted via Tsikot Mobile App
    Jul 2012
    oj88 - Thanks boss, try ko na din to mamaya
    wezz - hahaha, i think this is the culprit kung bakit nasira yung orig cable ko. My son uses it while charging, tapos naka bend na sya pabaliktad.
    Tip:
    Lagyan niyo ng spring ng ballpen para hindi ma worn-out yung cable laking tipid!
    Heres mine
    Oct 2009
    fake lang talaga ung mga after market na mga usb .maganda talaga ung galing sa unit ,,kapag bumili kaya di baleng gamit na basta siguradong galing sa unit or orig talaga..
    Mar 2004
    Buy a cable that's has "works with iOS 7" label.
    Jan 2009
    Most of the time, it's not true.
    The best thing to do is to test the cable before buying it.
    If reliability is of utmost importance, get the Apple original or a licensed/certified third-party cable.
    Jul 2012
    The problem is gumana sya the first week, kaso after that ayaw na. 550 pa naman bili ko dun sa cord na class A (2 meters kasi). Lesson learned, never buy fake chargers for apple products from now on.
    After claiming for warranty yung orig lightning cord ko, 1-2 months waiting time daw. Oh well, intayin ko na lang keysa bumili ulit ng ibang fake. Hiraman muna ng charger yung sa wife ko saka yung sa anak ko. :D
    Sep 2009
    yung sis ko, ilang balik na sa cdrking, under warranty pa yung cable. 2 days lang palpak na.
    Same thing sa akin, nawala ko naman cable ko so bumili ako sa crking works initially pero biglang may lumalabas na not certified and may not work. Bumili ako ng mas mahal na cable sa electronics botique 400 pesos so far ok pa naman. Kapag nasira baka bumili na ako ng orig ulit.
    ako nilagyan ko nang duck tape etong huling binili ko para hindi sya mahugot at mabend... culprit dyan pagnakacharge ginagamit kaso ang kulit nang anak ko.
    Bumili ako Belkin lightning cable, ayaw din gumana sa mga idevices ko for charging. But ok sya for playing music while plugged into my headunit.
    Signature
Fake lightning cable charger for apple products not working
