Results 1 to 19 of 19
    i went to World Food Expo in World Trade Center last Saturday to look for Espresso machine. I noticed that 99% of the Espresso machines are made in Italy. Do you happen to know any Espresso machine brand made in another country (except Italy)?
    May 2005
    share ko lang
    Yung isang network company ba napuntahan ko nag service ang technician ..nakita ko dami maliliit na ipis sa loob ng machine
    di ko lang sure kung saan made ang machine..malapit kasi sa drainage ang nakalagay
    at saka mahirap uminom doon di naman kumulo ang tubig ..pina init lang
    Jun 2006
    Quote Originally Posted by ineedmorehp View Post
    Usually, the best coffee machines are those made in Europe, like Germany and Italy.
    May american din pero those are normally made in china - which is lame. Espresso machines operate at very high pressures (9-20+ Bars), you don't wanna entrust potentially dangerous appliance like this to a chinese company. You'll suffer worse than 3rd degree burns if it explodes.
    Well, hindi naman ako bibili ng made in any other country except for Italy (for now)... Na curious lang kasi ako almost or all of them are made in Italy. Btw, can you recommend a good one for biz use?
    Nov 2006
    expresso machines can be very expensive. lalo na pag industrial size or quality.
    Aug 2005
    Depende how many cups a day...for small restaurant less than 80 cups a day, go for Saeco fully automatic (40k - 55k).
    ^ sir you have experience w/ Saeco brand, or any other brand? Was it easy to operate? THanks.
    Jun 2006
    Tingnan mo rin yung espresso machines ng starbucks at seattle's at cbtl.
    Sep 2004
    ok naman Saeco. easy to operate. i know Santis is selling this product.
    yun amin lang mabilis mag light up yun descaling indicator light.
    For home use I have a Krups brand. Its made in Germany and it has been very reliable so far. Checkout if the have espresso machines for commercial use. The ones I normally see are the small ones for domestic appliance use.
    Yeah i know krups. according to a friend not reliable for biz use. starbucks, figaro, and big coffee shops' espresso machine cost around 150-250K.
    just want to check others' experience on other brands of espresso machines.
    Mar 2005
    kung tinitipid at minadali ang gawa like yun galing sa china, malamang nga expresso machine yan hindi espresso
    ANy other brand? Suggestions? Mas ok ba yung automatic or semi-auto?
    Aug 2005
    go for saeco, proven and tested na.
    Oct 2004
    I'm guessing here but I would think the reason most of the espresso machines are Italian is because espresso is Italian?? (not trying to be a smartass)
    I personally use a Capresso/Jura automatic but I don't use it all that often since it needs to be cleaned after each use and if you're only going to make 1-2 cups, nakakatamad. But if it's going to be for commercial use, ok lang since you'll use it a lot more. Saeco should also be pretty good.
    I hear the semi-automatics and manual espresso machines have the potential to make better espresso since you're able to tweak the brew. La Pavoni and Rancilio are the brands I've been hearing. But you'd almost need to have a full-time operator for it since the preparation is quite involved. Yung automatic kahit yung bartender na lang ang mag-operate ok na.....
    Apr 2004
    pang-industrial use ba yun sa santi's? hindi ba for personal use lang yun?
    gusto ko yun sa ucc eh. ang cool
    Quote Originally Posted by afterglow View Post
    i attended a coffee seminar and yes you're right espresso started in Italy. I wanted an automatic because you dont need skilled barista for that.
    OT: according to the seminar barista = coffee, bartender = coffee + other drinks (cocktails, mocktails, etc.)
    What im not sure of is the accuracy of the automatic to produce constant amount of coffee ground and pressured water...
    Mar 2004
    Mmm... all this talk about coffee made me go to the pantry to whip up a cup of... eeeek.... instant coffee! :-(
    On the espresso machine --> Once you get a good machine, make sure you also get a good grinder. Don't skimp money by getting a cheap blade grinder. Instead, go for broke and get a good burr grinder.
    A blade (rotary) grinder cannot produce grounds fine enough for espresso use. Furthermore, blade grinders produce uneven, jagged grounds which lead to uneven coffee extraction (i.e. some granules will be over extracted while some will be under extracted).
    Burr grinders will ensure you have an even grind for espresso.
    Oct 2004
    Don't get me wrong...even an automatic can make very good coffee with near-perfect crema. It's just that the grinding & concentration can only be adjusted within some limited parameters and can't be as consistent as doing it manually and measuring precisely. Ang daming mga variables though by doing it manually....each bean has to have it's own formula of grind, tamping pressure, dosage amount, etc. Hirap to do it in a commercial setting.
    Just choose your machine (automatic), choose a bean, experiment until you find the right settings and stick to it. Should make a pretty good cup o' joe and be pretty consistent. Pero tama nga sabi ni van_wilder, the ones on display in Santi's are for home use only. If they're anything like mine, it'll only make two cups at a time (around 3-4 minutes/cup), need to go through a cleaning cycle, and can only make around 10 cups before needing to be refilled and cooled down. If you're talking about a restaurant/coffee shop you really need to be looking at a light commercial model. Saeco has a couple models that can make up to 50 cups/hour and start at $1300.
ESpresso Machine
