Results 1 to 9 of 9
    hi
    anyone knows a supplier or maker of elevator that can lift 100 to 150kgs from 1 to 3rd floor only... elavator thats look like a dog cage,ill use it in bussiness to lift stocks up and down thx
    Oct 2011
    you might be referring to a dumbwaiter.
    Sep 2008
    You are looking for a commerical Dumbwaiter.
    napakamahal neto sir. mahal kasi ang electromechanical drive niyan
    magfabricate ka nalang.
    check out Demag
    Quote Originally Posted by bmacavanza View Post
    check out Demag
    where is demag? do dumbwaiter and freigth elevator is the same?
    Sep 2008
    dumbwaiter up to 500kgs only. they vary in definition by manufacturer
    freigth elevator and dumbwaiter are basically the same except dumbwaiter is not design to load people.
    MHE Demag - better to call them to check if they really have a dumbwaiter. Mind you very expensive ang product nila.
    hanap ka sa yellow directory under material handling. forget ko na mga contact ko dati
    cheers
    hi
    anyone knows delca industrial parts supply and elevator elevator services
    i need feed backs with them
    thx
    Oct 2011
    pwede mo rin pa improvised ang forklift para makamura ka. to transport cargo from 1st to 2nd floor.
    Jul 2004
    or you can do it amsterdam style, i.e. yung mga pulleys located just outside the top floor window and pull the goods/cargo manually or through a small machine
elevator for house
