Results 1 to 3 of 3
May 20th, 2019 10:58 AM #1
It's a dual WAN router where I can connect two different internet sources into 1 router.
I have both PLDT Fibr and Converge in my office. I tried to connect Converge to the LRT224 but I cannot get an internet connection. Di ko pa na-try to connect PLDT, ayaw ko muna galawin PLDT since dyan naka-connect office network ko, ayaw ko muna galawin.
The Converge internet, kaka-install palang last week so hindi din ako familiar sa settings nya. But when I reset the supplied router, nawalan na ng internet. Need to call their hotline and have them remotely reconfigure the router.Signature
May 20th, 2019 01:56 PM #2
May 20th, 2019 02:49 PM #3
When you connect a device like a PC behind the Converge router, what IP address do you get?
When you connect the same device behind the Linksys, what IP address do you get then?
^ Ako I just use the good ole mini elm327 OBD2 scanner. Pero usually sa long drives ko Lang...
