Results 1 to 4 of 4
    Intel Pentium 4 1.6Ghz Intel Atom 1.6Ghz
    Which is faster at typical tasks such as web surfing, document and spreadsheets?
    Assuming the same hardware specifications (memory, hard disk) on either computers. And both are running MS Windows XP.
    I am just wondering if I should upgrade an existing system (P4/1.6ghz) using an Atom based system or should I go Intel Pentium dual-core since the Atom based system is cheaper and uses less power.
    The P4 is an old chip already so I would say the Atom might perform better... Pero kung kaya mag Dual Core mas ok yun kasi yung Atom pang low end na netbooks yun eh...
    Jan 2009
    Go dual-core.
    Atom is really made for low-power consumption which is a factor in mobile devices where battery life is a concern. For desktop use, the P4 would likely be superior over the Atom, everything else being equal.
    Jun 2006
    PCMARK2002 Scores:
    Atom 1.6 - 2494
    P4 1.6A 100 MHz - 3984
    P4 1.6A 163 MHz - 6425
Intel Pentium 4 1.6Ghz vs Intel Atom 1.6Ghz
