Results 1 to 11 of 11
    gurus out there please help...
    am experiencing this annoying pop out doctor antivirus warning from my kids lappy and saying it has detected harmful or potentially dangerous viruses and spyware.
    guess one of my kid tried to install this doctor antivirus but retreated when prompted with the buy or register prompt. also tried with same result. please help how to get rid of this annoying on and off warning! can't find from the installed programs either
    btw, AVG antivirus free version and spyware doctor were installed on their lappy. tia
    can't you not uninstall it?
    if you can't do a systems restore to the date where this was installed.
    Aug 2005
    Another method is:
    1. re-install it
    2. install Total Uninstall software
    3. uninstall the AV with Total Uninstall. Total Uninstall will remove all junk files of an application. It is an alternative uninstaller to Windows Add Remove Programs to remove programs completely
    4. problem solved.
    hindi ako po sigurado kong installed na sya dahil wala naman sa installed programs (using control panel at programs installed folders). restore date ay hanggang april 2008 lang (siguro earlier date ito na "install=diagnostic test").
    Another method is:
    1. re-install it
    4. problem solved.
    sinubukan ko na po sya pero gustong magbayad ako ng 50$ hehehe.
    para bang diagnostic test using this AV program pero pag nagawa mo na yung test ay no turning back. meron po bang ibang paraan? pasensya na po kasi limited lang ang alam ko pag ito na ang pag-uusapan
    one thing i've thought about is to make the drastic move...
    remove it via windows registry. search mo all strings related to the program.
    Jul 2006
    try to uninstall in safemode.
    double post...
    Quote Originally Posted by 1D4LV View Post
    tried ko na po going to windows registry pero di ko makita. meron 1 folder Doctor2008 delete ko na sya pero after reboot andoon na naman. hindi ko ma-attach yung print screen sa registry editor
    kailangan na siguro to call my expert technician.
Doctor Antivirus warning pops out always...pls help
