Results 1 to 18 of 18
    Nov 2007
    How do i clean the compressor of my split type AC unit ?
    anybody did this before ? i don't want to go thru paying aircon technicians anymore I can clean the AC unit and tear it apart vacuum all the molds (lumot) and clean out all the dirt and put it back together . The compressor cleaning i havent tried and i dont want to mess it up hehe. I want to do it myself from here on out i dont think its rocket science anybody with experience can help me out? thanks for your time and inputs
    Midea inverter technology 2.5HP me and wife's room
    my Daughters unit
    They just basically spray yun fins ng compressor...
    Sent from my iPad using Tapatalk HD
    Nov 2007
    thats all there is to it?
    wala kasi ako dito last time may gumawa sa house and yung bantay (houseboy) me memory gap di daw nya maalala panu ginawa
    Yup! Ganun lang ginagawa nila pag nagpacleaning kami sa office and dito sa bahay...Sabon Sabon konti then check yun freon level..but for cleaning that's all to it
    ganon nga lang basta na exposed mo na yung mga dapat linisin mga kung ano anong alikabok na nabuo sa loob basta walang charging of freon pwede naman DIY yan.. most of my AC unit ako nalang nag lilinis na kikita mo pa ng husto kung anong dapat palitan na malapit na masira
    Nov 2007
    Mabaklas nextweek ng magkaalaman na hehe
    Quote Originally Posted by kenzie View Post
    goodluck ingat sa mga clips at lock na plastic baka masira
    Nov 2007
    Quote Originally Posted by NightRock View Post
    Thanks ready na dibdib ko may masira kesa ibang trainee na pagprapraktisan ang compressor ko kpag nagtawag ako sa aircon company
    Aalisin mo lang naman housing ng outdoor unit, at least yun maaalis lang then cover mo yun motor mismo or malayo naman yun motor sa fins eh...then bugahan mo na, if you were able to clean the indoor unit, balewala na yun outdoor unit
    Sent from my iPhone using Tapatalk 2
    Nov 2007
    Yep once a month i clean the AC unit sobrang dali na for me sige try ko nexwik yung compressor unit sana nga easy lang din thanks
    Oct 2011
    parang bihira linisin ung accu usually ung fcu lang...
    Nov 2007
    Retz yan ka nanaman sa shortcuts mo ih ano ung FCU saka ACCU ?
    Jan 2009
    The problem with cleaning split-type ACs is managing the mess. The outdoor unit is the easiest to clean. You typically just need a pressure washer and a couple of rags. But cleaning the indoor unit requires some technique, a bit more preparation, and a lot of patience.
    If the indoor unit is situated above some fragile furniture or electrical appliances (my indoor unit is literally above my home theater), these have to be removed first. Professional cleaners always bring along a piece of "trapal" to catch the falling dirt as they also try to channel the drain onto a waiting bucket. But it's not 100% effective as some water splashes can get to the ceiling or wall.
    Oct 2011
    ung indoor unit yan ung fcu (fan coil) sir tapos ung accu (compressor) ung nasa outdoor.....
    BTT:
    pag cleaning ng FCU normally, they put a big plastic forming a triangular shape and then may timba sa baba pang salo ng tubig.
DIY split type AC compressor cleaning
