Page 3 of 3 FirstFirst 123
Results 41 to 60 of 60
    Jan 2016
    #41
    Thanks Sir Flipo.
    Oct 2007
    #42
    Quote Originally Posted by nowitzki41 View Post
    What is your current cctv sir?
    Sent from my LG-H860 using Tapatalk
    Just some brand I bought from China, 2 CCTV not working anymore.
    Sent from my ONEPLUS 5 using Tapatalk
    Oct 2007
    #43
    I suggest Dahua starlight wdr 2mp.
    Sent from my ASUS_Z017DA using Tapatalk
    Thanks sir, check ko sa supplier ko dito sa China.
    You can buy a replacment sir... just like mine, the lense got damaged and no display anymore...
    so i bought a replacement with similar wire sockets of my old cctv... they work fine...
    for compatibilty assurance you can bring your cctv dvr to the store where you will buy your new cctv cam for testing if compatible... also check your wirings maybe wire lang yung may sira...
    goodluck!
    Oct 2007
    #45
    goodluck!
    Thanks Sir!
    #46
    Thanks Sir Flipo.
    HTH sir.
    Ibigay nyo sir yung specs na post ko sa taas, and I'm sure marami pang latest o mas maganda dyan, depende sa budget nyo.
    [emoji848][emoji848]
    Reolink RLC-410 4MP PoE Security IP Camera review including how to install - YouTube
    May 2011
    #48
    I have close friend in CCTV business. Pm me, they're offering anything base on your budget. TIA
    Sent from my SM-G930F using Tapatalk
    http://www.congress.gov.ph/legisdocs...16/HB03838.pdf
    Just sharing...
    Oct 2013
    #50
    baket naman ganito na kapiraso bakal ay pag kamahal, 200 to 400 kesos kada piraso
    #51
    Quote Originally Posted by Stigg ma View Post
    400 bucks each!
    i am confident, there are significantly cheaper alternatives.
    one has to but look around.
    you might even make pa-sadya. i imagine, it'd still be much cheaper.
    Jan 2016
    #52
    I am planning to add at 2-3 more IP cams to my current one. I'm thinking of buying a 4-way power supply splitter to power up the others. If my current tp link IP cam is 9 volts 0.6 amps, then I would need at least a 9 volts 2.4 amps for all 4? There are 2 other variants I saw available, a 2 amp and a 3 amp. If I switch to a 3 amp, won't it overload 1 cam or say 2 cams only if I plan to add cams 1 unit at a time over several weeks or months or even limit it to 3 only. Also, will a 25 meter length work? I think this is the set up for 4-8 cam CCTVs which have wires as long as 20 meters? Thanks.img_20230928_125959.jpg
    Jan 2009
    #53
    A 9V with 3A (or higher A) power supply is fine as long it's of relatively good quality. Some crappy PSUs will say it's rated for 3A but folds at 1.5 - 2.0 A.
    The cameras require 9V but will only pull the current (Amps) it needs.
    Dec 2009
    #54
    the length of wire is a factor that will add resistance to the circuit and could cause a voltage drop from 9V and affect the camera operation. with longer wires between the power source and the camera, you may need a higher voltage than 9V
    as for the current, since your circuits require a total of 2.4A you will need to use a 3A maximum limit to ensure that your power supply can provide the current needed by each camera to operate properly.
    if the cameras are POE compatible you can supply the power through the network cables
    Jan 2016
    #55
    Thanks for the tip on buying higher amp Sir OJ88, so there's no harm using a higher amp supply than the requirement of the cam.
    Sir Kisshmet, is it safe to go up to 12 volts? There's no info regarding cam power requirements except the specs on the supplied adapter which is 9 volts. My unit is Tapo C320WS and I plan to add the same. Thanks.screenshot_2023-10-12-12-40-03-402_com.lazada.android-edit.jpgscreenshot_2023-10-12-12-38-40-561_com.lazada.android-edit.jpg
    May 2007
    #56
    ano ang recommended memory size for wi-fi camera?
    Jan 2009
    #57
    Don't use 12V. The current draw is low enough so voltage drop below a dozen meters or so can be ignored.... unless you're using very thin wires.
    These should work quite well.
    https://shopee.ph/TP-Link-TAPO-IP-CC...8-dab9ec5f669e
    Dec 2009
    #58
    its hard to say for sure 12V is enough
    the longer the wire the higher the resistance will be generated in between the power supply and the camera
    also, the bigger the size (AWG number..the lower the number the thicker is the wire) the lower the resistance will be
    so it depends on the length and the size of the wire that is used, what the voltage drop will be
    non technical people can do a trial and error..electronic engineers can compute it
    if tplink support wont tell you what the maximum voltage the camera will tolerate, then stick with 9V. if the length of wire you will use in a particular camera will cause it not to operate then the voltage drop is significant. in such cases use a thicker wire to reduce the voltage drop
    Jan 2016
    #59
    Thanks again OJ88 and Kisshmet, I guess I'll try to ask the advice of the seller which Oj88 recommended at Shopee.
    Sep 2008
    #60
    Planning to install Dahua Technology, WizSense NVR model DHI-NVR4108HS-8P-AI/ANZ and 6x camera model DH-IPC-HDW3666EMP-S-AUS
Cctv camera
