Results 1 to 19 of 19
    Jan 2003
    my sister is a globe broadband subscriber. plan 999 ata yung kasama fone. now she has a laptop and wants a wireless connection.
    will the linksys wrt54g work on globe? or do i have to look for another model. my smartbro works on the linksys wrt54g. di ko sure gagana sa globe.
    and also sa globe kasi pag gagamit sya ng internet, nag sign pa sya. sa smartbro laging on-line na kasi. do i still need to install anything on the laptop?
    tnx
    Pag prolink H9200 ang modem nya sa globe baka mamoblema siya. Pareho ang ip add nila na 192.168.1.1(prolink at linksys) , kung hindi naman prolink ok lang.
    Jan 2003
    hmmmm need to check on that, di kasi ako familiar sa set-up nung globe, but last time i fixed her PC, parang usb yung line ng globe.
    May 2005
    Tell Globe to change the USB Modem into a LAN Modem.
    Pwede naman palitan IP add ng mga routers. Any router should do.
    Any good WiFi router should be fine. Personally I have replaced my Linksys routers with TP-Link brand wifi routers (P2100/unit).
    Quote Originally Posted by impulzz View Post
    Nag sign pa sya? You mean parang dial-up that you have to enter a username and password to connect to the internet? If that's the case, globe issued you a modem in bridge mode.
    OK lang sana it'll work with most of the routers out there in the market, AFAIK globe is now using PPPoA (before PPPoE) after upgrading their systems to ADSL2. Most routers in the market only supports PPPoE but to make sure I suggest you call globe about this para naman sigurado ka sa mga kakailanganin mo.
    Hope this helps...
    Jan 2003
    ok guys pinuntahan ko sis ko kanina to check on the globe set-up.
    its like this....
    phone line > dsl filter > speedtouch 330 (its like a silver clam on the desk) > usb cable to the PC
    whitejack, yeah everytime she wants to connect to the net she signs-in like a dial ISP.
    so now di ko na alam anong router to buy, since usb ang connection from the speedtouch thingy to the PC. and the wrt54g only has a lan cable connector.
    I googled speedtouch 330 and found out that this one is a USB Modem (no LAN ports) and is designed to connect only a single PC to the internet. The best option is to follow sir andre's suggestion:
    Quote Originally Posted by andre View Post
    Because wireless routers use RJ45 as WAN ports.
    Another thing, I have a friend subscribed also with globelines, the ISP provided him with a ProLink modem router (4 ports) with wireless LAN. Maybe you could request globelines modems like these.
    Jan 2003
    ok tnx. will call globe for moden change. thanks
    Jun 2007
    share ko lang
    globe wireless ba? ZTE MF600 yung modem na kuha ko pwede naman siya sa linksys wrt54g ito gamit naming router pero balik kami smart bro kasi mas mabilis smart IMO
    Quote Originally Posted by washburn View Post
    share ko lang
    Mga sir tanong ko lang po anong wireless router ang gumagana sa Smart bro yung pong 999 pesos/month. Diko po kasi ganong kabisado at bago lang po ang connection namin. pwede po ba ito magamit kahit sa 3 computer.
    Ok po ba yung lynksys wrt54g ?
    TIA
    Jan 2003
    in my house i use smartbro and linksys wrt54g gamit kong router. 1year mahigit na and ok naman yung linksys on smartbro.
    i use linksys wrt54gs, this one has "speed booster" though i really don't know if it increases range and throughput. it's been on for more than a year, 24/7. three computers are wired to it and 2 laptops are connected wirelessly. works great.
    Quote Originally Posted by moe View Post
    Mga sir thank you po sa mga reply. Sir MOE saan po kayo nakabili ng linksys wrt54gs at magkano po ang kuha nyo. pasensya po dami tanong.
    kailangan lang po para hindi nag-aagawan yung dalawa kong angels sa internet.
    TIA
    Quote Originally Posted by Innova_G_2007 View Post
    TIA
    Should be available at PC Express. Not sure of the price though, as ours is wrt54g bought a year ago.... 100Mbps should be more than sufficient for a regular internet connection... so I am not sure what the speed booster is for, as the internet connection is a function of your ISP.....
    3909:trampoline:
    Jan 2003
    will this modem-router help with the globe connection? my sister remembered that the globe repairman told her to buy a router in greenhills or granada, but she forgot what exactly he said.
    The D-Link ADSL2/2+ Modem with Wireless Router (DSL-2640B) is a 3-in-1 device that combines the function of a high-speed DSL modem, wireless G access point, and 4-port Ethernet router. The DSL-2640B supports the latest ADSL2/2+ standards to provide higher performance (up to 24Mbps* downstream and 3.5Mbps* upstream) and longer reach from your Internet Service Provider’s (ISP) Digital Subscriber Line Access Multiplexer (DSLAM).
    cvt, nothing is said about increasing the broadband speed, linksys claims though that there's a significant increase in range and throughput from router to connected pc. i tried the linksys wrt54g before and i had connection problems, frequent disconnections. i brought it back and bought the wrt54gs. it works for me and it's really stable. by the way, 2800 for the wrt54g and 3500 for the wrt54gs , pcexpress prices.
    That's a good modem router sir, but I think you'll need the help of the globelines technician to configure the connection for you.
what router to use on globe
