Results 1 to 19 of 19
    Guys need help.
    I need to recovery a damage or non working hard disk co'z we need the stored files.
    here is the status of the Hard Disk:
    1. Cannot be read on Cmos/Bios
    2. Physically I Think may na sira co'z prang may mga mugmog or dumi akong nakita.
    I now possible pa ito ma recovery atleast kahit yung ilang laman.
    I just don't now kung saan reputable Technical shop pwede.
    Tulong naman po mga computer Wizard dyn.
    Thanks & God Bless!
    http://www.quetek.com/ file scavenger v3.0
    try that! check the site for more details
    http://www.quetek.com/download.htm
    May 2005
    Try troubleshooting first with the ff
    1.) Try the particular hard disk on other computers first. We have a busted motherboard here which cannot read or recognize (at "cmos/Bios" )any hard drives or optical drives attached to it. Tried it on another different working motherboard and the hard disks are still functional.
    2.) If you're hard drives are PATA. (parallel ATA), maybe you did not configure the jumpers on it to indicate whether its a master, slave or master w/ non ATA slave, etc.. Consult the website of the hard drive's manufacturer regarding the jumper settings.
    Kung hindi na madetect sa CMOS paano mo pa mapapagana yung hard disk?
    Sa akin kasi pag nasira yung HDD swap and try ko muna sa ibang computer pag hindi na talaga gumagana sa ibang computer palitan na.
    Sep 2006
    Ganito lang ginagawa ko diyan chief:
    1. Slave config
    2. Try ko ipasok sa external HDD enclosure
    IDE po ba yan o SATA?
    pero do we have any shop dito satin na kaya magrepair ng HDD just in case?
    Sep 2006
    Quote Originally Posted by Josh0027 View Post
    Meron po akong alam na nagrerepair sa TPC (http://www.tipidpc.com/). Search niyo na lang po doon chief. Doon ko nabasa dati yung service na inaalok na HDD recovery service.
    Quote Originally Posted by Kikkomann View Post
    thanks!
    Jan 2003
    try mo lang..
    i've read this somewhere, lagay mo sa freezer yung HDD overnight... no joke. tas install mo ulit. baka gumana.
    Dec 2003
    Quote Originally Posted by Puchok View Post
    Guys need help.
    Thanks & God Bless!
    i think for this instance... once the hard disk (HDD) is not detected in the bois. How can you recover a file from the HDD?.. so basically, the HDD is damaged and no more files can be recovered at this point.
    Try mo ibagsak sa floor with carpet yung HDD or lagay mo sa Freezer for an hour.. This is the last option done by some technicians. for after freezing the HDD for an hour or so, it may still run for 2-3hrs much enough time for the files to be recovered.
    Jun 2004
    try this www.infineon2u.com 9129433 somewhere in cubao area ata..
    Dec 2003
    Quote Originally Posted by A121 View Post
    try mo lang..
    di ko nabasa agad may nagreply din pala nito..
    Mga sir,
    Thank for all the replies.
    The hard Disk is I think damage physically.
    It is an IOMEGA external HDD. Binaklas ko na mismo sa Enclosure nya then try it isalpak s HDD s motherboard & also try to change the jumper setting wala ayaw talaga. ATA po ung HDD.
    ito pa talagang ayaw mag read dahil malalamn mo naman dahil pag nilgayn mo ng power supply yun dapat prang nag vibrate sya pro wala tahimik lang eh.
    So what I need now is a reputable shop na marerecommend nyo to bring the hard disk for recovery reapair, I mean not only to repair co's I need to recover at least khit 80% nung files na laman.
    Thanks!
    ahh ganito gawin mo..normally ang nasisira sa HD yung pinaka circuit board nya...hanap ka ng kaparehong model ng HD...pagpalitin mo yung circuit board...pwede ka naman manghiram muna....
    madalas mangyari sa akin yan...ginagawa ko papalitan ko lang yung board ng HD with the same board na galing sa kaparehong HD
    nakoooo never mo gawin ito..
    Try mo ibagsak sa floor with carpet yung HDD sa ibang HD ......
    Aug 2005
    check mo na lang sa tipidpc.com, pm mo din yung mga bumibili ng defective hdd if they can handle repairs too.
    http://www.tipidpc.com/viewitem.php?iid=632910
    http://www.tipidpc.com/viewitem.php?iid=585079
    http://www.tipidpc.com/viewitem.php?iid=616621
    Apr 2006
    search here www.tipidpc.com
    Jul 2006
    o well hirap nyan... you need a data recovery services company pag sobrang dead na yung HDD.... tsk tsk
    Sep 2006
    Just came across an article the other day where an intentionally burned HDD's data was fully (100%) recovered. Sa U.S. nga lang yung service. Even HDDs riddled with bullets, nasasalba pa daw nila.
    Sep 2006
    yup sa US dami nito kaso they are too expensive. tipong pang corporate use kasi. kadalasan pinarerecover yung mga vital files ng isang companya na.
    try mo http://www.drivesavers.com/
    not sure kung may partners sila dito. Recommended ito sa US.
    mga samples nila
    http://www.drivesavers.com/museum/index.html
    OT: Ito pinapatawagan ng mga tech support agents sa customers nila pag nagfafail hard drives nila na kailangan may irecover na files. hehehe
Busted/Damage Hard Disk! Recovery? help!
