Page 1 of 19 1234511 ... LastLast
Results 1 to 10 of 291
    Please help me choose a printer. It will only be used for printing documents (word, excel or ppt) and web pages.
    My previous printer was a Lexmark and has gone through my graduate and post-graduate papers! It's still working but the cartridge is already obsolete and I have gone through several refills on my last cartridge. It served me well for 12 yrs I need to replace it now with a printer that is basic since I rarely print documents. My budget is only 3k maximum. My priority is is durability.
    Here are my choices:
    Canon Pixma iP2770 Printer PHP2195
    Canon Pixma iP2770 Printer | VillMan Computers
    Print
    Speed*1
    Based on ISO / IEC 24734.
    Click here for summary report Black & White: A4 Plain Paper: ESAT: 7.0ipm
    Colour: A4 Plain Paper: ESAT: 4.8ipm
    Photo (4 x 6"):
    PP-201 / Standard / Borderless 55secs.
    Resolution (dpi)*2 4800 x 1200dpi (max.)
    Min. Ink Droplet Size 2pl
    Number of Nozzles 1472
    Cartridge Type PG-810, CL-811 (PG-810XL, CL811XL Optional)
    Epson Expression Home ME-10 PHP2495
    Epson Expression Home ME-10 | VillMan Computers
    Small Footprint – World’s smallest printer in its class; Designed to be 15%
    smaller than the previous models T13 and ME 32
    • Footprint refers to the desk area the device’s occupy
    • Low Cost per Cartridge – New economical Inks for only PhP 185 per
    black ink cartridge and PhP 355 per color ink cartridge
    • Individual Ink Cartridges – Replace only the color that is already ink-out
    • Peace of mind with extremely reliable Micro Piezo Print Head technology
    • Improved Productivity with print speed up to 24ppm
    Print Speed (ppm)
    24 / 13 (black / color)
    Dimensions
    15.4 x 19.6 x 11.2 in
    HP Deskjet Ink Advantage K010A Printer PHP2990
    HP Deskjet Ink Advantage K010A Printer | VillMan Computers
    Specifications
    Print speed black (draft, A4) Up to 20 ppm
    Print speed colour (draft, A4) Up to 16 ppm
    Print speed footnote Speed specifications have been updated to reflect current industry testing methods.
    Print speed black (laser comparable) Up to 5.5 ppm
    Print speed color (laser comparable) Up to 4 ppm
    Print quality black (best) Up to 600 dpi
    Duty cycle (monthly, A4) Up to 1000 pages
    Number of print cartridges 2 [1 black, 1 Tri-color (cyan, magenta, yellow)]
    Print quality colour (best) Up to 4800 x 1200 optimized dpi (from 1200 dpi input data when printing from a computer on photo paper)
    Standard memory Integrated
    Standard printer languages HP PCL 3 GUI
    Paper handling
    Paper handling standard/input 60-sheet input tray
    Paper handling standard/output 25-sheet output tray
    Duplex print options Manual
    Maximum input capacity (envelopes) Up to 5 envelopes
    Borderless printing No
    Media sizes supported A4; B5; A5; A6; DL envelope
    Media types supported Paper (brochure, inkjet, plain), photo paper, envelopes, labels, cards (greeting), transparencies
    Meron ako nung canon pixma, pinaconvert ko siya sa unlimited ink and I buy refill ink which costs 70petot sa recto. Isang refill ng ink kaya magprint ng up to 2,000+ pages. Haha.
    Here's the problem. Ink jet printers are cheap. But you will need to use them often enough so the ink will not dry up in the nozzles/print-head.
    The solution, get a LASER PRINTER. The cheapest ones are around P3,500 each with a toner capacity of around 1500 copies. You can leave this unused for a whole year then fire it up for a quick document print out with no issues (except if a rodent or family of roaches made it as their home).
    Jan 2010
    sir GH, magkano naman po ang pa-refill ng toner ng ganitong LASER PRINTER? Tanks in advance po...
    Quote Originally Posted by rmsoriano View Post
    If you refill your old toner cartridges, it's usually between P800 to P1200 depending on the cartridge model/size. Note that the print drum has a limited print-life and replacing that will cost you another P700 to P1000 depending on model. In my experience, a drum can last typically two to four refills before you need to replace it. There is also a "toner blade" inside the cartridge that will need to be replaced every five or more refills, costs around P300 I think.
    Jan 2010
    sir GH, maraming salamat po, might consider the epson L110 too....
    Quote Originally Posted by beni23 View Post
    Printer conversions are not recommended in C4U's case since she does not print on a regular basis. It would end up clogged and bubbles in the hoses.
    Oct 2011
    correct ka dyan sir GH, don't buy cheap refillable inks baka masira pa printer mo.
    ^ natetengga din yung akin pero di pa naman sira. Going 3 years na siya. Downside lang is naglileak na yung ink ngayon. Oh what the heck, hinihintay ko lang naman na masira na ng tuluyan para bumili ako ulit nung 3 in 1. Haha.
    Basta kahit ano mangyari wag na wag kayo bibili ng brother na printer, nakatatlo na kami at nasira lahat.
    At our office, since we need a printer for color, I got an EPSON L100. It was fine in the most part except it was quite slow.
    Previously we used a Canon IP1800 series printer with ICS kit. It worked fine except that I needed to replace the cartridge (color or black) around every 3 weeks or I had to run cleaning cycle often to keep the prints clear and bright. Basically it needed quite a bit of attention from me.
    The EPSON L100 was better in that it only needed its ink refilled and that's it. Once in a rare while, I might need to do a cleaning cycle but it's still a far cry from what I was doing with the Canon. Since the L100 was slow and we needed color prints quickly, I bought another unit, an EPSON L110 which was it's newer model and a bit faster too.
Best Printer: Canon, Epson or HP? 3k Maximum Budget
