Page 24 of 31 FirstFirst ... 14202122232425262728 ... LastLast
Results 461 to 480 of 601
    May 2005
    #461
    Quote Originally Posted by ZENMasterTYL View Post
    lakas sa battery ng 5, di ko naman ma off ang 3G
    got a battery pack attached to my ip5. god enough for whole day 3g browsing if needed. however, it can only fully charge ip5 battery if current charge is not below 20 % and you stop using it while charging using the external battery pack til it gets back to 100 %.
    cost = around 1.2t from your usual shop
    May 2005
    #462
    For globe yata you need to have your nano SIM replace for a nano sim LTE capable, it's free...
    Sa smart which I'm currently using Basta nano sim gingamit LTE capable na..
    Sent from my iPad using Forum Runner
    hi chief, nano sim says lte. how do i switch?
    Quote Originally Posted by fireblade View Post
    Yun booster batt ba yun? It was on sale last December Sa digital hub buy 1 take 1...
    #464
    im on globe unli surf, how do i activate and use lte?
    best app for me is magicjack as i get to call the US both mobile and landline for fre wherever I am.
    just update your ios. automatic na yan LTE once available in your location.
    Settings>general>network>enable LTE
    and yes Update to IOS6.1 then magkakaroon ng "enable LTE" undef network settings. Just switch it on...
    May 2005
    #466
    got that, it still says 3g from where i am right now here in taguig. parang makati and mandaluyong pa lang ang meron for globe.
    It means Wala paglobe LTE where you're located
    May 2005
    #468
    so it should say lte on the top left portion of the screen when lte signal is avail?
    Oct 2011
    #469
    Ano ba itong LTE?
    Ano ba itong LTE?
    Its what they call 4G, an upgrade from 3G.
    Nagtataka lang ako, sa listahan ng locations ng LTE ng smart eh nakalagay din kung anong establishment, like sa technohub eh nakalagay sa army navy. Does it mean yung LTE antenna eh pinapatakbo ng army navy at di galing sa cell site nila?
    #471
    Naka iOS 6.1 ako, pero walang enable LTE na option.
    Signature
    #472
    are you using iphone5? kasi yung 4s is not an LTE capable phone.
    Feb 2007
    #473
    Same here.
    Sent from my iPhone using Tapatalk 2
    Feb 2007
    #474
    Quote Originally Posted by freeloader View Post
    Same here.
    Found it. Just turn on "cellular data".
    Globe ba gamit mo? parang meron ako nabasa sa globe nagkaroon ng ganyan problema...ang work around daw eh thru itunes ka mag upgrade kung OTA ginawa mo
    the 3G will be replace by LTE
    May 2005
    #477
    went on 3g mode in rcbc bldg in ayala cor makati cor buendia. got a decent 1.6mbps and i guess that is lte at work.
    #478
    Quote Originally Posted by Bin Diesel View Post
    Yes.
    Globe nga ako and OTA ang pag update.
    Signature
    Yes.
    Try restoring thru iTunes, actually Wala pa rin Ako nakikitang LTE signal, Sa weekend I'll go around MM Sa mga lists ng LTE signals
    Mar 2004
    #480
    LTE should go faster than 1.6 Mbps, we already get 5-6 Mbps with 3G in Makati.
APPLE iPhone 5
