Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    SSD is quite expensive, but is a necessary upgrade? If indeed it is already a must, is 120gig more than enough? Is the brand of SSD also an issue?
    Aside from lesser booting time, what over advantages are there for an SSD?
    Quote Originally Posted by attyallanlatras View Post
    Upgrading to SSD is not necessary unless you want more speed/performance from your computer. SSD have faster read and write speeds. Also with no moving parts, they are not susceptible to issues of vibration and shock.
    Cheaper alternative would be hybrid drives with SSD cache on a HDD. It has a small SSD drive onboard the HDD. The SSD portion works as a cache but it is a "learning" system. So first time use, it will perform at normal HDD speeds.
    The basic choice is the standard high speed hard disk which spins at over 7000rpm.
    Base model hard disks spin at 5400rpm.
    Jul 2006
    cost of ssd does not justify the supposed advantage it has over hdd. besides, for consumer use, the increase in speed is minimal. unless, you're running io intensive apps, stick with hdds.
    Sep 2012
    if you have the money to burn, you will not regret upgrading to ssd
    Sent from my XT910 using Tapatalk 2
    SSD speed up your
    1. windows boot-up
    2. copying files to your HD (but you will not do this most of the time and promise you willnot make your SSD as your storage dahil maliit lang sya :D)
    SSD does not
    1. speed up your work.
    2. internet
    3. browsing
    4. make your appliction work faster
    dagdagan nyo nalang
    Jan 2011
    Quote Originally Posted by vh3r View Post
    SSD speed up your
    1. windows boot-up
    SSD does not
    2. internet
    3. browsing
    dagdagan nyo nalang
    Mali yung no.4, it will really make your apps to perform faster compared sa mechanical drives.
    Oct 2011
    vulnerable kasi ang mga protable hdd. kaya i gues it is worth upgrading to an ssd.
    SSD does not
    2. internet
    3. browsing
    dagdagan nyo nalang
    Applications will run faster when installed in an SSD. Also, it will speed up your work dahil yun nga, faster boot times, application run faster.
    Sir Atty, as of now, medyo ok na mag-invest para sa isang SSD drive, if you really need it badly. If not, then you're better with a mechanical HDD. Brand of SSD drive do really matter. Intel and Samsung SSDs are among the best SSDs when it comes to quality and reliability. Corsair, OCZ, are good when it comes to speed. Intel SSDs have better warranty policy here in the Philippines.
    I am currently using 2 128GB Samsung SSD in RAID 0 configuration on my video/gaming desktop. Kung sa laptop naman, pwede na ang 128/120GB kung di naman heavy user. Pero kung heavy user, 240GB SSD na ang kunin.
    Jan 2009
    Depends on the intended uses. The current truth is that, due to their higher cost per given capacity, SSDs are only economically viable for use on systems with which access speed and throughput matters. This means SSDs are typically the ideal storage medium to host the system OS or used as a 'scratch disk' as a way to improve response time and performance.
    SSDs are also used on most ultrabooks for the following advantages:
    1. Longer battery life - Conventional hard disks have continuously spinning disk(s) that requires power whether there's data actually going through it or not
    2. Less weight - Ultrabooks are meant to be portable so the need to shave off a few ounces here and there is a given
    3. Smaller / Thinner - It can be made to occupy a smaller footprint than conventional hard disks. In fact, most SSDs in ultrabooks are practically embedded on the system board to maximize the use of available space
    4. Instant-On - Simply put, who doesn't want Windows or OSX to be up and ready as soon as you press on the power button?
    But for multi-terrabyte raw storage capacity, conventional hard disks are still king.
    Dec 2007
    I've been an SSD user since 2010.
    I have a 40GB Intel X25-V SSD (that's it, in the center of the photo above) inside our Q6600 desktop PC and it loads Windows XP and the programs installed on it (OpenOffice 3.4, GIMP 2.6 and others) like you won't believe. I am a firm believer in the benefits of SSDs based on personal experience.
    Nowadays, the hard disk drive is the slowest thing in a modern PC (apart from the optical disk drive). No matter how you much you invest in a fast processor or add more RAM, the PC will only be as fast and as responsive as the slowest component - in this case, the storage subsystem. Picking any SSD over any HDD will give you a noticeable improvement in actual day-to-day use.
    On a desktop rig, the ideal setup is to have a small SSD for the OS and frequently used programs, which works in tandem with an HDD for everything else you have to store. There is little point in putting video, photos and documents on an SSD because you don't need the fast access on those kinds of files. A "small" SSD in this case can be 60-128GB, which should be enough for an installation of Windows 7 and a complement of programs and games.
    On a laptop, things are a little trickier because most laptops have only one drive bay. The best thing you can do is to get the biggest SSD you can find. 256GB is the current sweet spot; I'm holding out for a 512GB SSD to be made available here (although those will be very expensive). SSDs have a number of advantages for mobile computing: they are shock-resistant, more tolerant of high temperatures, and run with less battery power because of the lack of mechanical parts.
    SSD pricing has gotten a LOT cheaper in the past two years. My 40GB Intel X25-V cost me PhP5000 back in the day; you could get a 60 or 80GB SSD for that kind of money these days. The best thing is that they're getting cheaper and cheaper by the month.
    Branding can be important, but you're really paying for the SSD's controller. Many cheap SSDs use SandForce's SF-2281 controller, which had teething problems but is now quite reliable. Once the paragon of reliability, Intel's SSDs used to run off their own controllers, but lately they've used SandForce silicon too, with their own "secret sauce" firmware. Samsung is one of the best and most reliable SSD manufacturers, using their own NAND memory and controllers in the 830- and 840-series SSDs.
    Do SSDs have a read-write cycle limit like memory cards?
    Signature
    yes they do. But they usually have a built-in program to spread out the write locations over the entire disk to minimize over-use of certain areas.
    Dec 2007
    Yep. Read-write endurance is a fact of life for SSDs. Unless you are writing huge amounts of data to and from the drive though, the usable lifetime of an SSD is a non-factor for most consumers.
    Unless you're running Windows XP or lower, it shouldn't be a problem. There is an onboard "TRIM" command that balances the wear between the NAND flash memory cells on an SSD. Many SSD makers have their own optimization software to go along with their products too, such as Samsung's Magician and Intel's SSD Toolbox.
    In my case, Intel made up for the lack of the TRIM command on XP via its maintenance software.
    There is one thing you do have to avoid: Do NOT defrag an SSD. That has no benefit and just prematurely wears out the NAND flash.
    Oct 2011
    Baka ma obsolete na hdd sa susunod just like floppy disc.
    HDDs are still much cheaper than SSD. So most computer buyers will still go for HDD over SSD.
    Malabo pa yan. Sobrang mahal pa ng SSD ngayon. Give at least 5 years o more pa.
    And oh, another advantage of SSD over HDD is the weight ;)
    Aug 2003
    as others have said, until SSD prices go down and capacity improves the traditional platter-based HDDs are not going anywhere.
    Dec 2007
    Not anytime soon, but it could happen.
    As the process node lithography of NAND flash memory goes down, you can cram more memory into a given piece of silicon. This is the biggest reason why SSDs have gotten much cheaper over the past four years. You're essentially getting more yield out of the same amount of raw material.
    To give you an idea, my Intel X25-V back in 2010 was made on a 34nm lithography process. These days the newest SSDs are approaching 25nm, 21nm and even 19nm NAND.
    Oct 2011
    Yep, mahal pa kasi SSD ngayon. But slowly may nakikita na akong laptop ngayon na SSD na.
    Not yet if you're looking at regular laptops. The ones that feature SSDs are Apple and Ultrabooks. And even ultrabooks are going back to HDD to lower the selling price.
Is an SSD a necessary upgrade? If so, how many GIGABYTES is enough?
