Results 1 to 6 of 6
September 18th, 2008 08:40 AM #1
Our Innove(Globelines) ISP in our house is down for at least 2 days now. The AsyncDSL light was blinking, but the Internet light was off on the modem (meaning it was attempting to connect to the internet). I called up their 919-8888 and there was a pre-recorded announcement that they're doing some rehab or something with their network and so QC users will experience service problems. The CSR on the other line wasn't of any help, as expected...
However, my thinking is that I am from LPC and should not be affected. Their service was pretty much stable as I haven't experienced any downtime since it was installed a year ago. I also inspected and tested the physical connection last night up to the breakout box outside, and it was ok.
Not sure if you can reply here (if you're using Innove), but has anyone experienced any uptime issue with them lately? And where is your location, too? (Am using a different ISP in the office now).
TIA.
6707:choir:
September 18th, 2008 09:34 AM #2
ganyan din sa akin minsan bro (las pinas area), pero sa akin, ang modem ang may problem. minsan kasi, even though connected na ako, namamatay bigla ang modem ko as in nagpopower-off sya.
ang napansin ko lang is medyo mabagal sya the past two or three days.
September 19th, 2008 07:12 AM #3
Thanks for the reply bro.,- wala pa ring internet connection sa amin kagabi....
Wala rin namang maibigay na tulong ang CSR pag tinawagan mo sila.....
6707:choir:
September 19th, 2008 08:02 AM #4
same here in makati, past 3 days sucks, may connection ako, pero super bagal, 300++kbps max na yun, while dati lagi 1mbps tops. also called cs, pero wala din nagawa.
this morning, mukhang mas masama, dahil more than 5 times na ko na dc. kainis.
September 19th, 2008 09:48 AM #5
September 21st, 2008 07:30 PM #6
Nagkaroon na rin kami ng internet connection today,- pero mabagal... I am only getting around 800kbps sa speedtest.net vs. my subscription of 1500kbps.... Tatawagan ko na naman sila para ayusin ito....
Walang ginalaw,- sa labas ang diperensiya....
Ang kulit kasi,- pilit na connection ko raw sa bahay ang may diperensiya,- e sinasabi ko namang i-check nila kung mayroon silang re-routing, reconfiguration o reconnection sa labas dahil bigla na lang na nawala ang internet connection.... Tsaka, sabi ko di ba't may dala kayong service modem?- E di i-check nila sa breakout box sa labas kung makaka-connect sila sa internet....
Thanks for the reminder on the rebate bro. 1D4LV... Pero, hindi ko ang makikinabang nito, dahil paid-for ng kumpanya namin....
6707:choir:
Kami dati naglalagay ng chain lock ng motor or bike. Iba nakita ko literal na kadena at padlock.
