Results 31 to 40 of 48
February 25th, 2007 09:09 PM #31
The P4 HT is a lot smoother during multi-tasking than the single-core A64s I've used. It isn't THAT bad though... I mean, even on my old Duron system I can feel the slowness, but none of that freezing malarkey.
Does the sound stutter (sirang plaka/pirated CD yung tunog) when it freezes? Do you have the Cool n' Quiet enabled (try disabling it)?
OT: Re old stocks: There isn't much of a "spare parts" market here in the Philippines. Everyone I know replaces their computer when it breaks, and everyone has exactly the same hardware it has when it was bought.Last edited by Alpha_One; February 25th, 2007 at 09:11 PM.
February 25th, 2007 09:25 PM #32
Asrock tipid version ng Asus hehehe
Anong aasahan mo sa tinipid na motherboard?
Sa lahat ng nirerepair ko halatang-halata ang kabagalan ng ECS, Foxconn, Asrock, kumbaga parang ipit ang speed ng CPU.
February 25th, 2007 09:41 PM #33
I've found the source of the 'freezing'. it's caused by u*******. i guess i'll go back to using *******. but i'll observe further if it is really u******* that is causing the 'freezing'.
Originally Posted by Jun aka Pekto
February 25th, 2007 09:47 PM #34
The ALC850 sucks. Even I wonder why I'm not replacing it with a VIA Envy-based card yet.
Back to topic, how about antivirus software? What do you use? Some programs have performance issues when used with certain AV's (and vice versa).
February 25th, 2007 10:03 PM #35
As I expected, since sir syuryuken is looking for performance, you wont really get that from Asrock. Asrock was designed for stability & compatibility in the 1st place that's why you will notice such technologies designed in their product such as AGP & PCIe slots in 1 board, Graphics card slot for those integrated graphics-only chipsets, and thicker PCB boards (6-layer compared to 4-layer boards).
But then again, what really makes a good board? Ako I don't look at the brand name but rather on the chipset it has... I would rather choose a Biostar, Jetway or Sapphire board with Intel chipset rather than an Asus, MSI, or ECS board with a ULi or SiS chipset.
And the good thing worth sticking for the Intel platform is that they design the CPU, chipset and you can even buy an Intel motherboard. As for AMD, they rely on 3rd party chipsets so quality varies...
I am not sure if there is a microcode update or an errata for AMD CPUs... better check their website if they have a bug fix for their CPU.
February 25th, 2007 10:27 PM #36
February 26th, 2007 12:17 AM #38
i am now thinking that it's u******* with ZoneAlarm that is causing the problem. i have been using u******* for a long time and haven't experienced freezing. until only recently, when i switched to ZoneAlarm that the freezing occured. ZoneAlarm and Avast together doesn't freeze the PC, as have been observed that past couple of hours.
February 26th, 2007 04:36 AM #39
I think that happened to my HP laptop (P4-2.4ghz) which had Limewire installed. It had ZoneAlarm Free version which limited many of Limewire's outbound features.
I wiped the hard drive completely and never installed any P2P apps again. It's been fine since until the laptop fell off the roof of an SUV. Now, it's time for a replacement......iBook, perhaps?
February 26th, 2007 04:50 AM #40
OT
If it's just sound quality, I don't have good-enough ears to tell the difference between it and my Audigy 2 Value. As far as causing any instability or other problems. Mine has none to speak of except occasionally doing the "skipping record" thing on BF2's main menu. That's the sole reason why I have an Audigy 2 Value installed. That was under Win XP. That problem's not present with BF2 under Vista RC1 which is why the Creative card is disabled in Vista RC1. The Realtek's doing just fine.
Via on the other hand, has had a track record of unstable and quirky motherboards especially with the KT266 and KT266A series. I lost an Abit and a Soyo KT266A boards after 2-3 years while an older AMD760 board outlasted both and still works great in my wife's pc. The Abit simply died for no reason. The Soyo (Dragon+) lasted 3 years. So long as no cards were installed except an agp video card, it was great. But put anything on the last 3 pci slots and that board becomes very unstable. Granted, that quirkiness may not apply to other Via-based components like the Envy soundcard or the Firewire chip of my current pc. But, I learned to take the name Via with caution.Last edited by Jun aka Pekto; February 26th, 2007 at 05:04 AM.
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
