Results 1 to 16 of 16
    Ano mga advantage and disadvantage on both?
    iam3739.com
    Quote Originally Posted by drey View Post
    aircon:
    Pro: works even in hot weather.
    Cons: malakas sa kuryente
    cooler:
    Pro: works like an electric fan. medyo matipid sa consumption
    Cons: increases humidity, does not work in very hot weather.
    Evaporative Air Cooler:
    pro:
    -less power needed to operate
    -cools a big area effectively
    -costs less to buy
    con:
    -requires venting of air from inside to outside (change air) because of the rise in humidity. Since the system depends on water evaporation, if the air is very humid, the system will not work effectively. It would require installation of an exhaust fan or similar.
    -requires periodical water replenishment
    -water pad needs to be replaced eventually
    -recommended water tank draining if algae is growing inside.
    -can only cool 5 degrees from ambient temperature.
    AIRCON:
    pro:
    -can cool a room to a desired temperature (if sized correctly)
    -simple maintenance
    con:
    -consumes more power
    -more expensive to buy
    Aug 2005
    went to funeral na gamit lang air cooler, nung madami na tao ang init! sobrang humid nga.
    in contrast, sa italianni's sa ATC dati dahil outdoors, very effective and cooling yung air cooler.
    Quote Originally Posted by NazQ View Post
    in contrast, sa italianni's sa ATC dati dahil outdoors, very effective and cooling ung air cooler.
    Evaporative air coolers are effective when used correctly. In enclosed spaces, you will need either an exhaust fan or another A/C unit to condense the water from the air in the room.
    Thanks guys!
    iam3739.com
    Buhayin ko lang to kasi I am interested in buying one.
    Do I have to leave my window open in order for the air cooler to cool my room?
    iam3739.com
    I see... Thanks GH.
    btw, what is the most efficient aircon today?
    Dec 2002
    planning to buy one for the living room, what brand would you recommend?
    btw lto main office at east ave vehicle inspection office waiting area (open air) does have one. imho its better than industrial electric fans.
    Jan 2009
    We have a lot of air coolers at home and in church. They're ok when used in the open or semi-open venue. But inside a room, it's worse than just using a fan.
    And even if used outdoors, it is only effective when it's hot and the air has little humidity to start with. Otherwise, the air becomes stuffy and your skin becomes as sticky as a flytrap.
    Jun 2006
    In short, just get an aircon for no-hassles cooling.
    Evaporative air coolers are meant to be used with a steady exchange of air from inside to outside. This is to control the humidity of the room.
    Jan 2009
    That's right. Not all rooms in a typical house may have a through and through air circulation. In which case, air coolers are not the ideal solution. An air conditioner is the only way to go in such situations.
    Quote Originally Posted by RC-V View Post
    If you like industrial designs... the units with the IWATA brand does the job but doesn't look pretty.
    There is a company by the name of COLLENT (or something near to that) located in QC that sells evap-coolers that looks like dwarf aircon units complete with remote control. I used to have one of their units in my computer rental shop.
Aircon or Air Cooler (Evaporator)
