Page 1 of 2 12 LastLast
Results 1 to 20 of 39
    Aug 2003
    Any tips? Am currently using Globe prepaid, then nagsusubscribe na lang ako to GoSurf299. i also redeem Rewards now and then for mobile internet.
    Cheaper kaya pag Smart?
    Mar 2004
    Google for Globe prepaid tips and tricks ... currently using 246.00 monthly for 500 minutes Globe/TM calls, 1000 all net SMS and 1GB data ... good thing is you can rollover to next month any unused minutes, SMS and data ...
    Jan 2016
    Hindi risky ito? I read some people tried to avail of these bugs, but if you are unlucky enough to have Globe fix it before you register, then you will still be charged and get nothing.
    I am amazed, this is super cheap, for 300/month my starter plan, I only get 300 mins call Globe/TM, 300 all net texts and 200mb data, it can also be rolled over indefinitely.
    My colleague is using this and yes I am amazed pag nakita ko free minutes (unli ata globe to globe) and texts niya.
    Is that illegal? Or hack? Glitch?
    How come allowed kay globe?
    Bro much better ang internet connection overall ng Globe vs Smart imho. Stick with Globe. Mas mura internet sa prepaid nila.
    Jun 2017
    what lame country is this that not only on electricity and water and fuel do we save that we also have to be mindful of our internet usage?
    If you are using android it has a setting that you can turn off background mobile data. This means it will not allow apps to use the internet in the background while mobile. Also use Facebook lite and messenger lite of you must have these apps.
    How's that?
    How's that?
    Go to settings, then Data Usage. Then click the menu on the upper right corner. There should be "restrict background data" there.
    This will block apps using internet on background, but you will still be able to use internet when the app is on foreground. Also works only mobile data, when on wifi it won't be blocked.
    But of course it will also block your email and messenger apps since those are backgrounds. So you won't get update unless you sync the email manually or connect to a wifi.
    Feb 2005
    you could also restrict apps individually....
    Feb 2005
    these are actual call/text/data promos from globe, but someone or probably somebody from globe released to the internet a workaround or tricks as others say, that when you combine some of these combo promos it will extend the validity to 30 days instead of the regular 3-7 days...
    Jul 2015
    Texts/calls/data for 30days
    281.00
    500mins calls to globe
    1020 texts to all network
    1gb data
    Codes sent to you Sir.
    Aug 2012
    Quote Originally Posted by makyong View Post
    281.00
    1gb data
    Pa-share din ng code.
    Sent from my ASUS_Z010D using Tapatalk
    Aug 2003
    281.00
    1gb data
    Sorry for the late reply, it's been an interesting week...
    codes received, will try it out. Thanks sir
    Google's new Android app makes it easy to save mobile data on the go
    Might be useful for prepaid mobile users. Philippines pa talaga trial area nila ha. hehe
    Aug 2008
    The best ang package 5 sa akin. Add kalang ng 24 pesos sunlit na
    Jul 2015
    You can register gocomboikea35 up to 4 times for a total of 4gb data
    Jun 2017
    is this still available?
    Feb 2012
    Right now I'm using Smart's GIGA99 - 3GB shareable internet data + 600MB for YouTube, iFlix + Unli FB valid for 7 days. Promo is up till July 10 only, then it's back to 1.5GB and 300MB respectively. I'm using this in both my pocket wifi for home use and my celphone for mobile use. I can do PASADATA from the phone to the pocket wifi kung maubusan na ng load sa latter. I'm using it kasi with my laptop for browsing and occassional YouTube videos. If I want to do heavy YT viewing, I do it in my brother or sister's house where they have unli broadband data.
    Except for the network upgrades that caused some outage in the past days, okay naman connection ko with Smart. It's mostly 4G with switching to 3G infrequently at speeds of 21 to 38Mbps downloads and 21 to 33Mbps uploads. Of course, at such speeds, youtube switches automatically to HD, so sandali lang ubos na rin yung 3GB even before the 7 days is up.
    There is also SurfMax with unli data, with validity of 1/ 2 / 3 / 5 / 7 / 15 and 30 days. The only catch is it has an FUP cap of 800MB per day. Once you reached that, your speed is throttled. For Globe, the "unli" plan is even stringent, with a cap of only 3GB per month.
    Jun 2017
    TRUE SMART IS CHEAP but datawise you can hardly connect.
how to save on mobile internet
