Page 1 of 3 123 LastLast
Results 1 to 20 of 42
    free energy generator ? - what is your say on this?
    Aug 2004
    You can transmit power via induction to the coil from behind the camera.
    But more likely, there is a bettery inside the motor and linking the two terminals simply completes the circuit between the internal battery and the motor.
    Also note... the voltage tester reads positive voltage when his fingers accidentally touch the terminals. That's fishy right there, the tester is likely set on "resistance".
    Simple trick. But if he was really getting free energy, with five volts, he could have lit a small light bulb.
    Of course, you can't hide a battery inside a small light bulb.
    Shouldn't the voltage reading drop a little when connected to the motor? Constant lagi voltage? Palaging 5.92V
    Signature
    Aug 2004
    Even funnier is the way the voltage meter spikes to 2.5 every time he accidentally touches the probes with his fingers. That indicates that the meter is probably rigged.
    the motor and multitester are rigged
    the motor have a battery and smaller motor inside ... the coil will complete the circuit or 9V battery will just add its own to run the tiny motor
    the multitester is rigged to show 5.92 when probes are shorted (the reading jump to 2.57 when he accidentally caused resistive contact with his hands at 1:39) ... yes we have induced votage on our body from the power lines (a very low AC, high-impedance source), a 2.57VDC jump would never happen on a tester set at 20VDC when both probes are touched
    he never showed the reading on the 9V battery!
    nice trick!
    Free Energy Generator, title pa lang peke na.
    Jul 2006
    Permanent magnet generator.
    May 2012
    Free energy is the invention of Nicola Tesla. This genius inventor died a poor man coz when he proposed free enrgy in the early 1900's, the capitalists deprived him of financial help, thus, he used his own money to finance his free energy idea to his own downfall. Without him, we would not have AC generators, which could deliver energy hundreds of kilometers away. (teslasociety*aol.com)A Filipino inventor, Mr. Aviso, had harnessed tesla's secret. (pls see aviso energy).
    Now, the secret of free energy is used mainly in the united states. There are many emails that sell the secret but with a price (20usd). I hope this idea will be given free (plans, drawings and parts lists), so that we could save at least 10%-30% of our house energy.
    if you really want free energy then build a solar panel, a solar water heater collector, or wind turbine. the first 2 are powered by the sun, the last by wind energy. mahal lang nga ang mga components. for a 1 kilowatt system (solar or wind) you'd expect to spend something like a minimum of P20k na.
    Aug 2004
    Quote Originally Posted by light2light View Post
    If you could produce free energy, why sell the plans? Build the generator, sell the electricty back to the grid (which you can do in the US), and from the tens of thousands you earn, host a website to give the plans away for free.
    That is, of course, if it works. or if it works as well as solar, which actually DOES allow people to sell thousands of dollars worth of electricity back to the grid.
    Then it's not FREE.
    Quote Originally Posted by marg View Post
    Then it's not FREE.
    depends on how you define free. free here means no fuel costs.
    Cost of Equipment plus the cost of Batteries will bring the per KW cost over that of Meralco.
    PH has plenty of Sunshine and Wind yet not many people use Solar or Wind Energy because of the High Cost.
    I agree with Marg. Time and time again, I computed the cost of a photovoltaic system to partially power our office, if it is feasible to have some net savings if we convert to solar power. Unfortunately, the cost over the system's lifetime (batteries and solar panels wear out due to use or exposure) will still exceed the cost of electricity from the grid (Meralco).
    Even if the "fuel" is "free", the cost and operational lifetime of the system to generate electricity should be considered. Even if the source of power is "free" it does not automatically equal to cheap electricity/power.
    Jul 2006
    Kong mayroon lang sana ang 'pinas ng ganito...
    The German solar power plants produced a world record 22 Gigawatts of electricity i.e. equal to 20 nuclear power stations at full capacity
    Oct 2011
    kailangan natin yan dito sa pinas ng alternative source of energy to lower down our electricity cost. mahal ng electricity dito sa atin,
    Dec 2012
    Energy cannot be created or destroyed.
    Oct 2011
    This remind me of the bataan nuclear power plant.
