Page 1 of 2 12 LastLast
Results 1 to 20 of 45
    Aug 2005
    Naisip ko lang since nahihirapan ngayon ang ating fishing industry why not the government construct a canal from Manila Bay to Pacific Ocean via Laguna Lake.
    I think may proposal si Palafox to construct a spillway via Paranaque to Manila Bay. Bakit kaya hindi i-deretso from Laguna Lake to Pacific Ocean para dun mangisda mga kababayan natin?
    Mahal kasi nang isda ngayon, baka sakaling magkaroon pa nang additional pagkakitaan mga kababayan natin.
    What do you think?
    At the closest, Laguna De Bay is 20+ km away from the Pacific and while the elevation between the 2 bodies of water is practically the same, you still need to cut through an average of 400m thick rock. Unless you want to build a complex system of locks. And to be economically viable the locks have to be large enough to handle big cargo ships and tankers, small fishing boats won't be economical enough to justify the cost. And what about the depth of Laguna De Bay and Pasig River. Can they accommodate big ships?
    Apr 2014
    Tubig alat at tubig tabang. May mga di magsusurvive na isda imo pag natuloy to.
    Aug 2005
    Quote Originally Posted by chronicle View Post
    Baka may ma develop na ibang species nang isda naman siguro?
    Pass through lang naman sya. Fishing will be done in Pacific Ocean and to be transported sa Fish Port.
    Halong tubig dagat na ang Laguna De Bay dahil sa Pasig.
    Jan 2013
    Yep. Two ways ang direction ng laguna de bay. Usually palabas from lake to Manila Bay. Pero minsan high tide, pumapasok ang tubig alat via Ilog Pasig. Just not sure by how much or if significant enough. Baka mas significant yung basura at plastik kesa sa tubig alat
    Sent from my ONEPLUS A3000 using Tapatalk
    Jun 2005
    Daming properties ang sisirain neto
    Sent from my MI MAX 2 using Tapatalk
    Jan 2013
    I like how you think TS. Out of the box.
    Quote Originally Posted by skyglider View Post
    What do you think?
    i remember of the plan, some years ago.
    but for some, perhaps political, reason, the plan was conveniently forgotten ("shelved", is probably the politically correct word.)
    if you're gonna dig a canal from laguna lake to manila bay...
    you gotta build several bridges to make up for the roads na nawala
    not to mention the right of way problems
    ung skyway 3 construction mabagal ang progress dahil sa right of way problems
    poste poste lang yan
    imagine the right of way problems with this idea
    Papuntang Manila Bay palang iyan. Di pa kasama yung eastward thru Quezon Province. Matatapos iyan by 2250 AD.[emoji38]
    Sent from my SM-T705 using Tapatalk
    Onga pala
    Westward palang ung sinabi ko
    Jul 2013
    Based sa post earlier na closest point of Laguna Bay to Pacific is around 20km... And checking Google Maps... I think Masikap Quezon will be the closest point...
    So Bagumbayan Paete to Masikap Quezon (sorry, di talaga ako familiar sa provinces kaya estiate lang)
    Masikap to Cubao is only 115kms (4 hours as per Google Maps)
    I think it will be cheaper to just widen the road para yung huling isda sa umaga can reach Manila before noon.
    Or just build a train! (Mas malayo pa travel ng gulay from Baguio to Manila)
    In early 2015, the Thai Canal (102km long/400m wide) was estimated to cost USD 20-25 billion.
    If we build a canal at 20km long, 200m wide... $2B dollars pa din yun.
    Sep 2014
    Bat din lang sila gumawa ng flyover from Manila bay to Pacific Ocean para hindi makakdestroy ng marine life
    E di maging 7102 islands na kasi hinati mo ang luzon.
    The Suez canal was made because ships had to go around the Cape of Good Hope to get from europe to india and beyond. The canal in Panama was made because ships had to go all the way down to Las Islas del Fuego to go from the Atlantic to the Pacific. And you want this canal to do what?
    Nov 2017
    Harangin basura from laguna bay going to manila bay 🤣🤣
    Aug 2005
    Hindi lang 7102 kasi madagdagan pa isla sa loob ng Laguna Lake.
    Saka yung ibang plan pala is to decongest Metro Manila pero pag nagkaroon nito eh dadami lalo mga tao.
    Jul 2013
    Nahihirapan daw ang mangingisda ngayon sa part ng Manila Bay
    The problem will actually be " Right of ways." This will eat up a lot of funds with a seasoning of corruption.
    Going east i.e. the Pacific/Quezon province will not be much of a problem for "right of way" as its still mostly farmland and forests.
Canal (ala Suez) from Manila Bay to Pacific Ocean via Laguna Lake
