Results 601 to 610 of 861
November 3rd, 2009 10:00 AM #601
4H on NLEX????
Better have your front differential and transfer case checked!
The Montero is a part-time 4x4, just like most hard-core offroad vehicles. But unlike the high end Land Cruisers or Land Rovers, it has no center differential.
Thus, the 4H and 4L is only designed to be run on mud or slippery surfaces. Running it on a pavement, even when wet, at 4H will cause "binding". Prolonged us will break your front differential and/or transfer case.
I suggest you read your manual again on how to properly use your vehicle.
November 3rd, 2009 10:27 AM #602
November 3rd, 2009 10:39 AM #603
on the place where i live ..when ever i caught with a heavy rains on the road i always tried my 4h and shifting it while its running at the speed of 80 to 100 kph and i dont have any problem
November 3rd, 2009 10:40 AM #604
quick guide sa super select 4wd. ewan ko lang kung parehas sa models sa pinas ito
http://www.grupo-minicar.com/mitsubi...tero/ss4ii.htm
November 3rd, 2009 10:53 AM #605
November 3rd, 2009 10:59 AM #606
Super select has nothing to do with it. It simply means that you can engage 4x4 without stopping when running fast on rough or slippery surfaces.
Are we talking of the same local Montero model? The local model does not have full-time 4-wheel drive. The mere fact that it has 4H is an indication of that. That is why you have a selector lever or switch for 2H, 4H, or 4L. Pag full-time 4-wheel drive, walang kang selector for 2H kasi naka full-time ka na nga, eh. So you only have High or Low.
The only reason your front differential or transfer case did not break is because you may be generally travelling in a straight line (as indicated by your 140 kph speed). But do it in a curve or zigzag road, and they will surely give.
Anyway, just want to help. So it's your own look out if you won't take it.
November 3rd, 2009 11:12 AM #607
- Oct 2009
- 3
November 6th, 2009 04:26 AM #6082000 patrol GU ZD30 engine 4x2 m/t all stock--170 kph SCTEX loaded with 6 passengers, more than half of rear filled with bags, 3/4 fuel tank (and easily reaches 140-150 kph on star toll, NLEX, SLEX), so not bad for a 9-year old rig!!
2001 urvan escapade 12-seater 130 kph SLEX
November 6th, 2009 08:19 AM #609
80kph using a 2002 Revo DLX Diesel.
Floor pedal na yun, basta 80kph ang bagal umakyat hehe.
- Dec 2008
- 9
November 21st, 2009 09:47 AM #610140 kph on a 97 power eagle.. Ahh.. Those were the days.. Pero easy driving na Lang si "choppy" ngayon.
Are they on track to surpass last year's sales?
Car Sales Data (2025)
