Page 3 of 3 FirstFirst 123
Results 41 to 55 of 55
    Ungas, tnx... so rwd ang trooper... tama ba?
    benny010::: For your model yes it is a rwd. Even the previous models that use to be 4WD, rear diffs perform during 4X2 function.
    Ungas, tnx again... can you refresh me on the advantage of rwd over fwd?
    Open diff ang front diff ng 4x4 Trooper.
    Advantage? Superior traction vs. RWD. Pero the best pa din ang front and rear diff lock combo. hehehe. Kaso ang mahal. Huhuhu....
    actually ungas di ba natanong ko na sa iyo iyang starex LSD to strada, since same mitsu parts,
    PK balitaan mo lang ako kung go ang project mong iyan
    kimpOy & Ungas, Wala na-curious lang ako :D A pajero rear axle in banawe only costs 3500. If a starex lsd axle only costs as much id definitely go for it. Unfortunately, di ko alam kung magkano presyo.
    keep me posted sir
    benny010::: Hmmm... Kung maalala ko sabi sa akin dati ng mekaniko parang tao at kariton yan. Di ba mas may bwelo pag patulak imbes na pahila ang gagawin sa kariton? I guess tha same basic law of physics apply to RWD and FWD vehicles. Mas hirap daw sa akyatan ng bundok ang FWD, lalo na pag malalaking sasakyan, take for example the MB100 (sample lang po sana walang magagalit :mrgreen: ). May nababalitaan ako hirap daw ito umakyat ng Baguio. Kung patulak naman like Space Gear, then the advantage of the RWD comes in.
    Kung city streets naman ang usapan, mas malakas ang hatak ng makina pag pahila. Power from the engine is more direct to the tires, not as to the RWD na dadaan pa ang power sa propeller shaft na mahaba, then diffs, then tires.
    Imo, I could only sense that the advantage of FWD comes from automotive factories. Mas mura daw gawin and ang parts nito.
    Ungas,
    May MB100 kami. Wala namang kahirap hirap umakyat ng bundok. Problem with the MB100 is transmission noise (masyadong magaan ang flywheel ng early models). Its not a design flaw but it can get annoying. So pagdating sa akyatan, a lot of drivers are afraid to rev the engine dahil natatakot sa tunog. Pero if you can bear the noise and watch your tach, you can make the MB100 dance up Kennon Road even with 15 persons (and their luggage) on board.
    As for the advantages of FWD, in road driving it equates to greater traction since the engine is sitting on top of the drivewheels. That's why an MB100 can climb slippery ramps backwards without breaking traction.
    Quote Originally Posted by OTEP
    Ungas,
    OT lang. .sa un kennon raod?.. alam ko handle kasi un ng isa dto.. hehehe
    kennon road is one of the roads going up baguio city. ito yung me lion's head ng lion's club. ito rin yung nasa logo ng baguio oil, yung U-shaped na daan.
    Signature
    That's what I was explaining, kung patulak ang power mas madali ito kesa pahila ang gulong aakyat ng ramps.
    Ungas,
    wala namang appreciable difference in climbing capability (on a dry paved incline) between a RWD and FWD... it really won't matter kung 'patulak' or 'pahila', the power of the engine is much, much more important.
    mbt::: Yes, wala nga difference kung dry pavements. I mean, di naman tayo laging dry weather and if wore comes to worse there are times that we encounter traction problems with FWD on uphill with wet asphalts.
    Engine power is another point, but correct tranny gearing will also have to be considered to match its power. :D
    tnx :P
wats the meaning of LSD?
