Results 1 to 10 of 10
January 7th, 2007 08:33 PM #1
found something..
ok ba to?
The Kia Pregio kit was developed 3 years ago by Turbo-Glide
The advantages of the Kia Pregio turbo kit include:
Exceptional response to turbocharging
Overall economy is improved with no visual exhaust smoke
Reliability and longevity are not affected
Power is increased a minimum of 30% as indicated by dyno report provided on completion
2 year unlimited kilometre warranty
Unique to Turbo-Glude this installation includes:
High flow Garrett GT25 turbocharger
Full sports exhuast system and vastly improved air filtration system
Acceptable engine mileage that installation can be performed is 300,000km plus on inspection.
Fitting time: 2 days
source:http://www.turboglide.com.au/index.c...&Product_ID=34
January 7th, 2007 11:45 PM #2
While turbocharging is not rocket science, I'd still recommend using a bolt-on turbo kit or having a competent engine modification job do the install (both are expensive). Turbocharging is very stressful to an engine especially one that was not designed to be turbocharged in the first place. In Korea, Kia uses 4d56 turbo engines for Pregios instead of turbocharging the 2.7 engine. They get the engines from parent company Hyundai. But it did require some re-engineering. I guess the cost of adapting the vehicle to the new engine was less than the cost of having to engineer modifications to the 2.7.
The Starex makes 99bhp in non-CRDi form, 145bhp with CRDi. An MB100 makes 105bhp. The old Hi-Ace Grandia 3.0 made 88bhp, IIRC.
January 8th, 2007 02:32 AM #3
Those are two very different engines. The innova 2.5 uses a common rail engine. Turbocharging your 2.7L will make substantial additional power but aftermarket Turbo kits are quite expensive.
BTW, Hyundai Starex' engine is really powerful. It'll be more powerful when they release the VGT version (Variable Geometry Turbo). It'll probably make 170hp using the same engine. The 2.2L SantaFe CRDi VGT has 150Hp/335Nm Torque (180Hp/395Nm with upgraded ECU). The Hyundai CRDi 3.0L CRDi VGT produces 240Hp/480Nm (stock performance) which powers the Veracruz LUV.
The only thing i hate about Turbos is the need to cool it down. No one has thought of hypercooling it yet (AFAIK). You need to idle for a minute or two to cool your Turbocharger or it would fail prematurely due to overheat (and it's very expensive to replace).
January 8th, 2007 07:20 AM #4
but driing in manila traffic wont make you need to cool down the turbo.
you can put a turbo in your engine, it is how it is done is whats more important. Or you can swap a more powerful engine and keep the original. when its time to sell reinstall the original to preserve the resale value.
January 8th, 2007 09:44 AM #5
Starex Turbo... yummy... I've been driving my Dad's new Starex GRX whenever we see each other, and I just have to say... that 2.5 turbo makes the Innova's seem... limp. Too bad the Starex is so heavy...
January 8th, 2007 02:17 PM #6
...and quite bouncy. But it is powerful
kerikzb,
the difference in hp that you're talking about is not solely attributed to the turbo. although the turbo will give you the extra horses, other technology was at work to generate a lot of that power. and turbo charging does not come cheap, and does require some maintenance, so you might be better off looking for a ride that's already more powerful.
Tsikot Member Rank 4
- Oct 2004
- 1,054
January 8th, 2007 02:46 PM #7wag mo nang galawin pregio engine mo .... tama si imm29, jsut get another vehicle that is more powerful .. coz turbo charging yhour pregio might give you more headaches plus the cost might be more than what a pregio van is valued now
January 8th, 2007 03:48 PM #8
