has anyone ever heard of this? or can someone explain what causes this?
i dont know if this happens to my trooper. but during the mornings, especailly
right after leaving my home, i would often find my trooper stuck at first gear,
refusing to shift to second gear. i dont know why. kahit konti lang apak ko sa accelerator. but after a few minutes or so sometimes 30 mins ok na siya. but there is something that i do notice during the day times. there will be times when bigla nalang magshishift to lower gear yung ride ko pag nag a-accelerate ako (kasi i want to speeed up/overtake).
its wierd kasi para akong nag engine break kung sa manual e.
yung i-fo-force mo to lower gear yung sasakyan kahit hinde pa dapat. yung effect is tataas yung rev ng vehicle at napakaingay ng engine tuloy.
it happens when i try to overtake or want to speed up. and mind you hinde naman mabigat yung paa ko. is this gear slippage ba? or something else? sa gabi kasi ok yung takbo niya e. kahit anong tapak ko normal yung shifting at tama yung ingay ng engine.
i hope i explained it right or someone will be able to understand yung sinasabi ko kasi i often get replies na "ay ganun talaga manual" or "baka kasi kulang sa power" pero its not that e as a driver mararamdaman mo naman kung under powered yung vehicle or kung kelan siya dapat magshift and ive been driving for almost 10 yrs na so i know na parang something's off. i hope someone can help me here.
thanks.
Try mo yung recommendation ni ARB. Kung may problema pa den, you may have a fried transmission. Certain operating conditions can result in heat buildup in the transmission second gear set and may lead to gear tooth chipping. In very rare cases, gear breakage can occur. Delikado ang gear breakage. Gear failure could result in transmission lock-up, and a crash could occur without warning. I've only owned Honda cars (5) and a Lexus (a '90 ES250) in my lifetime so my info could be limited. Yung auto transmission ng Honda is a lot like a manual transmission. Yung filter screens sa Honda transmissions are deep within the unit. Hindi sila accessible. Ang hindi ko maintindihan sa Honda is why they insist on such an odd design for their automatic transmissions? Other cars use planetary gear sets and brake bands, but Honda continues to insist on building it like a manual transmission converted to an automatic, with 3 shafts and clutch packs standing in for gears sliding along the shaft for engagement. On older (86-89) Accords, the 3-4 clutchpack drum would crack, preventing it from holding hydraulic pressure. Mawawalan ka ng 3rd gear. It was common enough that Honda came up with a redesigned part to address it. Di ko lang alam kung ganito din ang set up ng Isuzu transmissions.
