My transfer case support and front differential bushings are worn out. The transfer case bushing is the one near the driver's side while there are three bushings holding the front differential (two ahead, one behind near the oil pan).
I went to Mitsubishi and they could not supply me diff bushings. Apparently, too few people notice or check these things.
I went to M7 bushing fabricators along Quirino Highway (near Chieffy's old station). They said they will replace the diff and x-case bushings for Php 2,000.00 pesos (materials and labor). Is this a good deal? They will use engine-mount bushings and reuse most of the OEM hardware.
I also need new CV joint-inner boots. How much are these things supposed to cost? I'm not getting OEM because I need a bigger boot to compensate for the suspension lift. The present boot is too short and cannot cope with the driveline angles I encounter.
Thanks a bunch! Miss you guys so much.
