Results 1 to 7 of 7
    Mga Sir I owned a isuzu BIGHORN, the problem is nasira ung pindutan ng power at normal drive.. meron po ba nag rerepair nito. kc napansin q ang tagal nya kumambyo tsaka pag nasa nlex aq running at speed of 90 kph pag tinapakan q ung gas ng knti para bumilis mag shift pa sya ng third gear tpos bgla na lng ulit mag 4th dati ndi naman po sya ganun.. conected po kya un ng masira ung pindutan ng power at normal drive q?
    Tnx and more power..
    You must be referring to the A/T mode switch. In which case, Power means the transmission will shift at a higher revolution. And your switch might have broke while it is in the Power mode. If it was the switch itself that is broke, you can have it replaced with any toggle switch that can fit into the slot.
    sir may alam po ba kau gumagawa ng ganito?
    Aug 2005
    *batosai
    paki edit naman ang mga post mo. bawal kasi ang text speak. Just a friendly reminder.
    *batosai
    FYI batosai.
    Aug 2005
    Kahit na puwede mong mapa down shift ang A/T, di ito papayag na mag over rev ang makina kaya siguro nag up shift kaagad. Remember diesels have much less rev range than gasoline engines.
    Quote Originally Posted by batosai View Post
    I think kahit sinong magaling na mekaniko ay mapapalitan ang switch na ito. Iyon lang nga baka ibang switch na ang ikabit.
    salamat po sir..
    Try q na lng muna humanap ng switch sa mga surplus shop tsaka q papalitan.
    Sir ask lng ulti normal lng po ba na * 2500 rpm e 11o kph lng ang takbo q my engine is 3.1 turbo inter cooler. (4jg2) Kc feeling q parang kailangan na pa tune up?
    Tnx
Diff Between Normal And Power Drive? Need Help
