Results 1 to 7 of 7
February 11th, 2008 11:12 AM #1
Mga Sir I owned a isuzu BIGHORN, the problem is nasira ung pindutan ng power at normal drive.. meron po ba nag rerepair nito. kc napansin q ang tagal nya kumambyo tsaka pag nasa nlex aq running at speed of 90 kph pag tinapakan q ung gas ng knti para bumilis mag shift pa sya ng third gear tpos bgla na lng ulit mag 4th dati ndi naman po sya ganun.. conected po kya un ng masira ung pindutan ng power at normal drive q?
Tnx and more power..
February 11th, 2008 06:07 PM #2
You must be referring to the A/T mode switch. In which case, Power means the transmission will shift at a higher revolution. And your switch might have broke while it is in the Power mode. If it was the switch itself that is broke, you can have it replaced with any toggle switch that can fit into the slot.
February 12th, 2008 03:06 PM #4
*batosai
paki edit naman ang mga post mo. bawal kasi ang text speak. Just a friendly reminder.
February 12th, 2008 03:12 PM #5
Kahit na puwede mong mapa down shift ang A/T, di ito papayag na mag over rev ang makina kaya siguro nag up shift kaagad. Remember diesels have much less rev range than gasoline engines.
I think kahit sinong magaling na mekaniko ay mapapalitan ang switch na ito. Iyon lang nga baka ibang switch na ang ikabit.
February 13th, 2008 04:37 PM #6
salamat po sir..
Try q na lng muna humanap ng switch sa mga surplus shop tsaka q papalitan.
Sir ask lng ulti normal lng po ba na * 2500 rpm e 11o kph lng ang takbo q my engine is 3.1 turbo inter cooler. (4jg2) Kc feeling q parang kailangan na pa tune up?
Tnx
Since yung spare tire nasa labas ng sasakyan. Ano tawag dun sa lock na nilalagay sa spare tire para...
