Results 1 to 12 of 12
    Dec 2007
    Just checking to see if I will need to pick up a power converter for the Alcohol injection Demo at clark since our pumps are 12 volt units.
    Thanks.
    May 2004
    majority of turbo diesel suv's are 12volt dvldoc. except to some models of toyota land cruisers afaik.
    I think the 4D56 powered Space Gear used a 24 volt system... CMIIW.
    Dec 2007
    If your demo unit is a Trooper, you've got nothing to worry about
    some engines that are used for trucks find their way to 4x4 vehicles so you would have some toyota and mistu engines using 24v. Japan Military jeeps using 4dr6 uses 24v older model Toyota Land Cruisers use 24v too.
    Dec 2007
    Quote Originally Posted by Type 100 View Post
    We got 1 Trooper for sure, I just want to make sure I can install on as many vehicles as possible so people can see and feel the difference themselves.
    I have a quick connect which will allow me to temporally install a kit on just about anything in about 10 minutes. Just don't want to burn up a pump on a 24v system.
    im not disagreeing with this statment.. but i havent seen a space gear with 2 batteries, unless of course that one battery is 24 volts... and from my experience some SUVs, like landcrusiers have 2 batteries but still use a 12 volt system... just my 10 cents... heheh
    May 2004
    Quote Originally Posted by cocoy View Post
    halos lahat ng nakita kong local space gear ay dalawa baterya. not sure lang kung 24V system sya o starter lang ang 24V the rest e 12V.
    Sep 2006
    From local experience, only Jap trucks use a 24V system.
Which Turbo Diesels use 24 volt systems
