after getting an oil change...I checked the underside of my pickup...shucks something snapped...eto ba ang CV boot? can the part be replaced or the whole tbar na?
grabe naman nangyari dyan. alam ko pagbumili ka ng tbar as whole eh pero antay natin mga ibang gurus dito baka may solusyon pa
*notEworthy27
may warranty pa ba ride mo? grabe naman nangyari dyan..naputol bigla yung part..ni-lift ba yung ride mo nung nagpalit ka ng oil? baka dun naka-center yung pressure ng lift kaya naputol??
wala eh...tapos na yung warranty year '01 yung strada ko. when I took the picture nakaakyat na yan. It was during the oil change. Bihira naman na ipwe pwesto nila sa may tbar. I'm sure that it was caused by something else...siguro galing sa offroading namin sa maarat nung weekend na yun..
hindi ko ma visualize. malapit sya sa crossmember ng transmission support nasa transfercase side? rightside ng picture front ng strada? hindi kaya binagsak yan sa pagbaba sa lift?
passenger side po ng strada iyan. nung nakataas po yan nung kinuhanan ko po ng pics. hindi kaya na pwersa po siya sa offroading naten?
did you hear something break sa offroad natin? naka lean na po ba sya on one side? mukang ok naman stance ng strada nung pababa tayo... pag putol ang torsion bar bagsak suspension mo on one side
well ok pa naman stance ng strada. I don't think it would make the tbar useless if I took off the metal slack. parang takip lang eh. What do you think?
The object in the picture is the 'back end' of your torsion bar.
Is the torsion bar bent? If not, I think you just popped the torsion bar boot. Ask your dealer if they stock fresh ones.
That is not the CV boot. The CV boots are boots for the halfshafts that send power to the left and right front wheels of our rigs.
napupwersa ba ang torsion pano ito nangyayari? Madali ba ito nasisira? magkano kaya replacement mahal?
eheheh tanga tanga ko matagal ko nakita ganyan ko punit parero :D
di ko lang pinapansin parang plastic yan e
kailangan bang palitan yan? or pwede hinde
off topic
parang mahina ang strada ...
parang dami nasisira my p-up only has 30k plus kms pero nakapag palit na ako ng balljoint ....core heater.....speedo cable....may ibang part pa ako na di maalala![]()
speedo cable? diba adjusting lang yan? core heater? para san yun? anong year model ng strada mo sheep?
kung yung rubber lang ok lang na wala. pero yung tinutukoy ko yung bakal...
Otep Torsion bars are not bent.I think torsion bar boot lang nga. so yung front end yung may adjustment screws? So is it safe to remove the borken components?
Heater core is the equivalent of the a/c system's evaporator. It is what makes the cabin heater work.
When you crank the t-bar, you tighten the screw at the back-end (near the tranny).
Alisin mo na lang when you already have new boots.
Hindi ko makita kung ano ang problem sa bakal, eh. Baka malabo mata ko.
It should be wrapped around the tbar mismo. pwede kayang tanggalin na lang? Dang, I wish I had a better camera...
front end pala itong pic ko, near the front wheels. :D
Front end? The front end of the t-bar ends in the control arm diba? That looks like the back-end of the t-bar to me since it ends in the tranny crossmember.
Malabo nga... di ko pa rin malagay sa isip kong passenger side yan, that would mean you TB is cut off going towards front end. Prop shaft yata yung nakikita ko sa bandang likod.
post ako pics ulit. kuhanan ko tomorrow....pati ako nalilito na rin...
tama po kayo lahat! hehe back-end nga yung part na pinost ko. hehe . atsaka plastic lang pala. hmmm...parang bakal nung ginalaw ko before? siguro lumambot na...kelangan bang palitan ito?
