Page 3 of 3 FirstFirst 123
Results 41 to 52 of 52
    Quote Originally Posted by S-works
    magandang gabi po sa inyo, at sana mabigyan nyo ako ng kaunting advice sa problema ko
    my truck is an '02 ford ranger 4x4, w/ about 33,000 kms na...and for the third time since december, nagkaroon sya ng overheating problem. having brought this unit to ford makati for service twice na for the same problem in 4 months, i needed a second opinion na so i went to ford connecticut.
    after about 45 minutes with the engine running with the mechs looking at the engine from different angles, na tancha ko na di nila alam kung anong problema ng sasakyan ko. susuko na sana ako... tapos may biglang dumating na tech support from FPG, at pinabukas nya radiator cap ko...pina-start engine ko...tapos napansin nya nag tatapon ng tubig ang radiator sa top pag tinapakan ang accelerator. ang duda nya, may leak galing sa makina at posibleng warped cylinder heads, or leaking cylinder gaskets, or both.
    may nakita rin akong thread tungkol sa overheating dito, at base dun sa isang post, maaring totoo yung suspecha ng taga FPG (sigh). nalulungkot ako kasi, eto ang estimate ng casa:
    cylinder head assembly - 49,5000
    cylinder head gasket - 3,200
    labor - 10-15k depende sa aktwal na problema
    pag warped ang cylinder head, puede naman daw i-machine shop kung di pa ganun ka grabi ang pagka-warp nya, at kung sa ganun, mabawasan naman daw ang gastos ko.
    ang mga tanong ko sana ngayon:
    1) sa labas ng mga ford service centers, meron ba kayong ma-recommend na shop na magaling sa ganitong klaseng trabaho?
    2) kung sakali man may ipapalit na pyesa (cylinder heads or gaskets), meron bang ibang outlet ng original ford ranger parts na mas mura?
    3) sabi ng ford connecticut, kung ma-machine shop pa ang pyesa, sa Precision machine-shop daw nila ipagawa....magaling ba yung shop na yun?
    kung may advice kayo mabigay tungkol dito...maraming salamat in advance!
    My friend had a similar problem with his Toyota Forerunner. He had several bout of overheating and later, when he had the vehicle checked at one of the shop, they found a cracked in one of the cylinder head. One of the options recommended is to replace the entire assembly with "surplus" one, which they say would be a cheaper option. He called Toyota, and he was quoted for 39T just ffor one original single cylinder head.
    Appreciate any recommendation from Tsikoteers, where to get surplus cylinder head assy for Toyota Forerunner.. thanks.
    Aug 2004
    It should be replaced under warranty. A brand new vehicle shouldn't overheat no matter what.
    Dec 2004
    Quote Originally Posted by niky
    Hell our '92 Charade has been up and down Baguio, and was an integral part of the construction of our current house (brought tiles, fixtures, including the kitchen sink!). It hasn't overheated even ONCE to this day. Not bad considering the tiny square radiator the thing has.
    Aug 2004
    Unfortunately, if a driver uses a diesel engine in anger and doesn't care for it (i.e.:revs it like a gas engine all day long), it will wear down quickly.
    Andami kong kilala na may negosyo na van rental, and they've had to overhaul lots of engines (mostly Nissan Urvan and Toyota HiAce Grandias) because of abuse.
    teka... hindi ba dapat mas matibay ang diesel engines compared to gas engines in the long run?
    Jan 2004
    true. but any machine when abused will eventually give up and broke down.
    Aug 2004
    Yup. The thing with diesels is, yes, they're much stronger, but at 4000rpm, there's more pressure on the cylinder head and walls than at 6000rpm in a gas engine. That's why diesel rentals break down so often.
    Dec 2002
    s-works,
    whats the update with your ranger ? is the engine still ok and whats the present mileage
    onga..
    naiintriga ako sa ranger..
    so ung mga may problem ung ranger na made in the PI?
    friends ranger has the same proble. when he went to the dealer to complain that coolant is always being replenished, alam na alam na ng dealer na cylinder head daw ang sira. that week 3 sila nasira-an. ngayon more than a month na hindi tumatakbo ranger niya, mahal daw b-new head. ano kaya ginawa nila s-works and the others? bili ng surplus engine and get the head only?
    and to think that some say that the ranger is a reliable vehicle. PNOC fito sa amin nag re rent ng pick-ups they specified any pick-up except the ranger daw.
    from the posts below, S-works' ranger seems to be fine na.
    my ninong has had his ranger for two years na and no problem whatsoever. nalibot na ang buong luzon. everyday ibinabyahe sa provinces to pickup generators and heavy rewinding equipment wala naman reklamo ninong ko.
Servicing cylinder heads & leaking gaskets
