Page 5 of 9 FirstFirst 123456789 LastLast
Results 81 to 100 of 176
    May 2004
    Buti pa dalhin ko n lang sa shop nyo. Sino ho ba hahanapin kung tatawag ako. TIA.
    May 2004
    Originally posted by Doc Diesel
    you can avail of carbon clean services in Betan Calibration, 240 Pablo Ocampo Sr. St., San Antonio Village, Makati City 8992819 and 8952566.
    look for James, Mercy or Dave.
    Doc Diesel
    Uuuupppss, nasa previous post pala. Tnx Doc, tawag na lang ako.
    Jan 2003
    doc
    if there are problems and you cannot proceed with the carbon clean, can your shop fix it and then proceed with carbon clean? or do we need to go to another shop to have it fixed?
    thnx
    Feb 2004
    excited na ako sa check up and carbon clean ko this saturday
    andy
    Originally posted by buknoy2002
    doc
    thnx
    kung engine problem, we may be able to help but it would depend on the availability of the mechanics since we sometimes do overhauling pero for a select few only....
    kung fuel injection system problem naman e we can definitely help you!
    then proceed with carbon clean.
    Doc Diesel
    Jun 2004
    ola mga Tsikoteers!
    1st, I am very happy na may ganitong club/forum. So happy to be part of it!
    Question: May alam ba kayong pwedeng pagdalhan for carbon clean sa Baguio City?
    (kung wala, dadalawin ko na nga lang talaga si Doc Diesel)
    Feb 2004
    as i was looking for these for these myself, here are some of the fuel system cleaning additives i saw in a nearby mall hardware:
    Max44™
    Cleans Fuel Injectors & Carburetors
    Cleans Intake Valves, Manifolds
    Reduces Combustion Chamber & Intake Port Deposits
    Fuel Injector & Carb Clean
    Improves performance & saves gas
    Reduces exhaust emissions
    Helps keep injectors, carburetors & fuel system clean
    Fuel Injector Clean Up™
    Super Concentrated
    Cyclo's most powerful formula - one bottle cleans injectors fast
    Restores lost power & performance
    Dissolves injector & manifold deposits
    Helps maximize fuel economy
    Stops uneven acceleration & rough idle
    Carb & Fuel Injector Cleaner
    Pro-Strength Formula
    Cleans carburetors, fuel injectors & the complete fuel system
    Dissolves gum & varnish to restore maximum protection
    Nitrox Hot Shot increases B.H.P by up to 10%
    --Cleans the fuel system removing gum and dirt build up in injector systems.
    --Cleans carburettor combustion chambers and cylinder heads.
    --Use once a year as a system cleaner or more frequently as a power boost.
    --Not suitable for diesel engines.
    View Profile Re:decarbonized cylinder
    « Reply #6 on: June 29, 2004, 07:56:36 am » Reply with quote
    Will the above cleaners have the same effect as a decarb?
    Does a decarb also include whatever these cleaners do the injector?
    Nalilito kasi ako e. I want to boost my engine's efficiency. Ano mga dapat gawin?
    Feb 2004
    let's wait for some professional opinions on those products. interested din ako sa mga replies about them. ako kasi, walang alam sa mga ganyang bagay.
    andy
    Doc Diesel: Several Questions lang po, hope you don't mind answering (or others who has a pretty good idea on what the answer is hehe)
    I drive an 82 Mercedes W123 200D (2.0 diesel 4cyl with over 200,000km siguro)
    1) Coming from Buendia cor. Pasong Tamo (Export Bank Plaza) san po shop nyo?
    2) What's your real name para kung hahanapin ka.
    3) May konting leak ako sa engine, but I can't seem to find the source, most likely sa oil sump or dun sa parang gasket ng injector pump ko. Will this be an issue?
    4) I don't know if I have loose compression, but my engine runs quite well for a car this age and di naman gaano kausok. What usually do you do to check an engine's condition pag dinala sa shop nyo?
    5) For a car this old, do you recommend doing Carbon Clean? Daming soot na siguro to hehe
    6) Lastly, how long will this take?
    If it's easier for you, you can PM me or email me at david*bigberts.com
    Thanks a lot.
    Aug 2003
    pparado: there is no carbon clean in baguio yet but i think there is one in shell oasis service center in san fernando, la union. inquire na lang at the oasis service center in naguilian road near st. vincent's for confirmation re carbon clean.
    ok, there is only one know fuel conditioner / engine cleaner we know of that really works but it is only available in the U.S. since they need it more there because of their climate. well, actually wala talag silang engine cleaner since diesel's here are so clean you will hardly see any soot coming out of their pipes.
    as for those products that claim to clean your engine and or your fuel system.......I personally would not recommend them. Why? They have chemicals that can damage the internals of your fuel injection system which will lead to premature wear and tear. Whether local or imported yung product it still has the chemical which may not work best for you guys due to several engine working conditions.
    Para bang yung:
    1. Engineer na nilagyan ng kerosene yung diesel nila for a catamaran......
    2. Yung friendly mechanic who advised you to put a little gas for more firepower....
    3. Jeepney Drivers who mix kerosene too for a little push....
    .....they all ended up with having to overhaul their entire fuel injection system.
    as I have always said...go ahead and try it.....should I schedule you for an appointment within 6 mos. to 1 year?
    Doc Diesel
    Jun 2004
    diesoline,
    thanks, good idea!
    Wala kasi ako dyan sa Pinas, e. Si misis lang ang nagdadala ng sasakyan...kaya ipapa-check-up ko ng lubusan pag-uwi ko. And I need all the info I can get my hands on kasi sandali lang ang time ko sa Pinas.
    Dito pa lang, I can already plan my It re: the car maintenance!
    Maraming Salamat ulit!
    Make a right going to JP Rizal, then left on Pablo Ocampo Sr. St.
    Anthony J., but then I am in the U.S., look for my brother, Dave.
    We would have to find the leak first and patch that problem then proceed, if ever. Like I said, we don't want you to waste money on some repair that you won't benefit from.
    The surest and foolproof engine diagnosis is a compression test.
    Any vehicle, truck, stationary engine etc. of any year or model that the carbon clean machine can be attached to can be done.
    Depending on the engine size kasi, so for you the most would be 2 hours.
    [SIZE=1]Edit: Inayos ko lang po yung quotes para di nakakahilo basahin. -Ungas[/SIZE]
    Aug 2003
    doc diesel, would carbon clean help the trooper 4jx common rail and the patrol zd30 engines? There are claims kasi na maselan daw ang mga engines na ito dahil sa dirty philippine diesel, so mabilis daw magstuck up ang injectors ng patrol at ma overhaul ang trooper. Since late last year lang supposedly pinasok ng big 3 ang clean diesel nila, accumulation from the previous years will eventually affect the cars that used the "unclean" diesel. Would carbon clean help the older suvs (2001-03) to improve, maintain, and avoid these expensive problems?
    it is true that any common rail equipped engines are so sensitive that filter checking is a must ......however....we haven't used carbon clean [AFAIK] on common rail since we haven't really entertained a client with smoke problems on common rail....
    common rails should have the fuel filters check as often as possible....carbon cleaning is I think out of the question since they shouldn't really be emitting carbon from your pipe not unless it's defective...
    Doc Diesel
    Doc Diesel
    san nga uli yung exact address nyo sa makati? tsaka ano naka name sa pwesto? tia
    Aug 2003
    hmm, good point, sir doc diesel. Thanks! Am I right to assume that for those troopers that have followed the casa maintenance schedule yet encountered problems, need to inspect their fuel filters more often than the casa recommended schedule to avoid mistake? Would you have a recommended inspection sked, like, every 1K or 5K?
    Thanks Doc: I'll find time to bring my car in for a checkup and possibly the CC process
    Feb 2004
    bad trip, na-delay nanaman ang check up ko sa davao. this weekend nanaman
    andy
    Nov 2003
    Doc, bukas ba ang Makati branch niyo pag Linggo? Or are any of your branches open on Sunday? How about Saturday?
Sarap ng CARBON CLEAN!!!
