Results 1 to 6 of 6
    Does it mean that your nozzles and injection pump are still in good shape if you passed the emission test? Last January emission result for my TD42 engine is 0.010 or was it 0.10.
    Aug 2004
    Wala bang black smoke? They should be, then.
    pag unang hirit lang. then after that ok na. kasi napaisip ako the last time pina check (adjust opening pressure) ko sa denso yun nozzles sabi nila good for 20,000km pa, eh lumampas na ako ng mahigit 10,000km o 15,000 pa ata. baka pa check ko nalang ulit. feel ko kasi medyo malakas siya sa crudo.
    Aug 2004
    Have you cleaned out your exhaust? Baka may carbon build up sa exhaust kaya mausok sa first "buga".
    a bad nozzle can also pass the test. but your result seems good.
    I did an "italian tune up" before ako mag pa emission. Was surprise nga kasi last year .016 dati yun and it went down dramatically when I did that. Thanks for the info.
Relation between emission test and your injectors/pumps
