Results 1 to 6 of 6
January 24th, 2003 02:51 PM #1
Guys,
Di parin mamatay ang problem ko with regards my ride... meron paring tug-tog pag nansa lubak/uneven surfaces. Replace the rack-end and tie rod pero nandun parin.
Pina-check ko sa tireboy they hunch na baka yung lower suspension bushing daw. kasi as they saw it and i saw it too medyo malaki na yung GAP. Here's the tricky part... yung suspension bushing 4k+ isa... yung bushing sa taas( dalawa daw kasi bushing ng MPV) 1k isa... kaso kung sira narin patin Ball joint ko... palit na buo which is the lower arm bushing... which is 12k+ so the big question is... antayin ko nalang ba na masira tsaka ko na palitan lahat? Or palitan ko na muna bushing (lower suspension bushing) ngayon then after how many years or kms palitan ko naman yung suspension arm with the ball joint..
Opinion niyo naman... mahal sobra ng piyesa! kasi takot ko pag nasira yung lower arm suspension bushing damay nanaman lahat... sayang naman yung ginastos ko..
thanks
January 24th, 2003 03:41 PM #2
mdpo,
Try replacing the bushings first. It may do the trick. Try also to canvass for your bushings sa Banawe at baka makamura ka. Try sa Sprint. Goodluck. :wink:
4x4ph.com
- 695
January 24th, 2003 04:26 PM #3yep, canvas first...
hayy hirap talaga ng may sasakyan! para kang may anak na nasa college!
January 25th, 2003 05:57 PM #4
Contrary to popular Philippine auto repair protocol, lower balljoints rarely fail (they are not a load bearing component). Nasanay lang kasi tayo sa philosophy ng mga talyer na 'palitan na lang lahat' a.k.a. the 'tinatamad kaming mag-diagnose' philosophy.
Hindi ba supposed to last the lifetime of the vehicle ang suspension arm? Hindi wear out component iyan.
Palitan mo muna ang upper and lower control arm bushings. That usually works.
June 12th, 2007 12:52 PM #5
bushing lang yan bro...trust me...i had mine checked sa casa mismo and sabi nila shocks na raw costing 14k 2pcs front.. yun pala lower suspension bushing lang. tsk tsk tsk...buti nalang nag tanong tanong muna ako. replace mo muna bushing...
- Dec 2002
- 2,335
June 12th, 2007 03:04 PM #6change the bushings bro. experience ko naman pag suspension bushing mas ok yung original. mas matibay so tumatagal and hindi nasisira yung goma. di pa ako nakakatiempo ng replacement japan na up to my standards. mahal din kasi yung labor and yun nga yung kain ng goma mag su-suffer pag lumuwag agad yun.
see my pahabol statement above. i mean, i can go on vacation anytime. but my spouse has her...
Traffic!
