Results 1 to 10 of 23
October 2nd, 2003 01:07 PM #1
http://www.isuzuengines.com/JB_4jb1-pu.htm
di ba walang glow plug direct injection? :confused:SPECIAL FEATURES: * Direct Injection
* Glow Plug Starting Assist
* Replaceable Cromard Dry Liners
- Jul 2003
- 579
- Jul 2003
- 63
October 3rd, 2003 09:59 AM #4Originally posted by Bubbles
May glow plug lahat ng diesel engine.
October 3rd, 2003 07:04 PM #6Originally posted by Bubbles
Ang pagkakaalam ko rin wala ito sa mga direct injection.
Baka ka para sa cold climates ang GP.
October 3rd, 2003 07:23 PM #7Originally posted by Skywalker
Wala namang glow plug ang crosswind ah..
wala ngang glow plug ang crosswind and it's siblings or big brothers (fuego, trooper, NKR, elf trucks)
malamang nga sa cold climate lang. para i-improve yung flow ng fuel pag malamig at i-preheat na rin yung fuel bago pumasok sa pre-combustion chamber ng makina.
October 3rd, 2003 07:38 PM #8
Sa pagkakaalam ko rin may glow plugs ang diesel engines. Kailangan ito lalo na pag papaandarin ang makina sa umaga.
- Jul 2003
- 579
October 4th, 2003 12:34 AM #9RSNALD, paki explain naman.
paano magiignite ang diesel na walang pre-heater? mas mataas ba ang compression ng Di kaya isang compress lang ng piston mataas na ang air temp?
possible magstart ang diesel na walang GP pero matagal na pihitan ito ng starter. And like my engine na 24 volt, sobra lakas ng starter, bilis pihit makina, start maski walang pre heat pero kung 12 volts lang, di naman ganun kalakas starter..???
DIY to death!
- Jan 2003
- 451
October 4th, 2003 04:32 PM #10Diesel engines don't burn fuel by ignition (ie. spark plug). On the intake stroke, the piston moves down and draws air only. When the piston moves up, it compresses the air, thereby raising its temperature. Then fuel is injected and consequently burned by the hot air, producing power.
Kapag malamig, malamig din ang cylinder. So this has the effect of reducing the temperature of the compressed air, which might result in hard starts. Thus, heater plugs are used to compensate.
Hope this helps!
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
