Results 1 to 10 of 16
May 18th, 2005 12:50 PM #1
guys, is it possible to convert my AUV's rear leafspring suspension to a springtype one?
Tsikot Member Rank 3
- Dec 2003
- 546
May 18th, 2005 12:52 PM #2yay,
sa pinas walang impossible, bat gusto mo gawin yan? Malalbog nga ang Leafsprings, pero ang tibay naman.
- Dec 2003
- 546
May 18th, 2005 01:19 PM #4comfort== IFS or macpherson strut
pag durability solid axle/leaf sprung suspension
depende sa gamit mo. pero sakit durability ehhe sa hirap ng buhay at mahal ng parts, ok lang ang leaf sprung sa comfort para saken
May 18th, 2005 02:59 PM #5
kaya yan, yun nga lang magastos.
maraming control rods ang kailangan mong ilagay para macontrol yung paggalaw ng axle mo. sa leaf spring kasi, yung leaf spring na mismo ang nagcocontrol sa movement ng axle. ang coils, pwedeng mabali (mag-flex) in any direction, kaya kailangan ng control arms.
and auv's were made to carry loads (thus the name- utility in asian utility vehicle)
May 19th, 2005 10:46 PM #6
but does it mean that the more leaf spring you put in your vehicle the more stiffer the ride will be? plus why does some vehicle have a more bended leaf spring than that of other vehicles? how does it affect one's performance?
Tsikot Member Rank 4
- Oct 2004
- 2,315
May 19th, 2005 11:05 PM #7may mga nakita ako 4 ang leafs 2 sa front and 2 sa back. Ano advantages pag meron ka leaf sa front?
May 20th, 2005 12:59 AM #8
Leaf spring front suspensions are old school but they are heavy duty and easy to service on the field.
Converting your rear suspension into a coil unit is not impossible. But it will be expensive.
The only good thing is you have the potential to adapt the Montero Sport's rear suspension since you are using basically the same frame.
May 24th, 2005 03:18 PM #9Originally Posted by jvdejesus05
more leaves = stiffer ride and higher loading capacity (afaik)
more bended leaves = stiffer ride and higher loading capacity
there are reversed leaves which will soften the ride :D
- Dec 2003
- 546
May 24th, 2005 04:29 PM #10suspension is tuned according to requirement, some vehicles that has leaf sprung suspensions are for offroading, kaso after ppl buy it and use it as a urban truck, nag rereklamo sila, so manufacturers have to tune it depende sa market, kaya minsan pareho model iba iba yung bilang ng mule.
Number of leafs depende din sa vehicle, the more heavier the vehicle mas madami or masmakapal ang leafs. Dapat tama tama lang ang leafts para di matagtag or hindi bouncy, Kaya minsan pag bouncy are ride, nilalagyan nila sasakyan nila ng weight para mag match ang Leaf suspensions tigas sa weight ng sasakyan
If you think about it, if the price of the battery does not go down, replacing the battery of a...
Mitsubishi Xforce
