Results 1 to 8 of 8
    i have been thinking of doing this kasi parang mas maraming 5 holes na mag wheelz na available sa market na mura kesa sa pang 6 holes ? so tanong ko lang if anyone has tried doing this ? or ako pa lang nagbabalak :D is it safe kaya ? anyway i wana know your opinions fellow tsikoteers :D
    Feb 2006
    bro if I were you hwag mo na alng palitan, mas better kung 6 holes compared sa 5 holes
    I've heard of these kinds of installations. Some were even from 4 holes to 5 holes. What they do is they fabricate an adaptor to fit and bolt on to your 6 holes on one side, which then has 5 studs on the other. I think offset might be a problem with it tho.
    Sep 2006
    ok lang kung 100 to 114 or 114 to 100 or 5 studs euro to japanese 5 studs. delikado yan bro.
    ic thanx sa mga input nyo buti na lng nagtanong muna ako :D
    Aug 2004
    What car, by the way? If it's not used for heavy work, it might be okay.
    But the problem with offest on a hub adapter might mean your choice of mags will still be limited due to the increase in hub offset.
    L200 po sir , di ko na ginagamit pang karga eh pamorma na lang :D
    Aug 2004
    Ah. Andami namang 6-holes na choices doon na fit sa L200... added gastos lang ang hub conversion, konting tiyaga lang siguro sa paghanap.
has anyone tried this 6 holes to 5hole conversion ?
