Page 4 of 5 FirstFirst 12345 LastLast
Results 61 to 80 of 82
    speaking of ZD30, hindi underpower siya sa patrol?
    sabi kasi ni sir boybi medyo nahirapan nung paakyat sa tagaytay highlands nung fun run ninyo.
    pano pa kaya kung lagyan ng 4x4 components
    Nawalan lang siguro ng bwelo, alam ko nga mas malakas pa ang torque band ng ZD30 sa TD42.
    eh how about sa HP rating mas mataas na yung ZD30 kesa sa TD42? sorry di ko talaga alam
    ZD30, 3 litre, turbo-charged inter-cooled diesel, 4-cyl, 4 valves/cyl, dohc, power: 116kW at 3600rpm, torque: 354Nm at 2000rpm
    TD42, 4.2 litre (4169cc) naturally aspirated diesel, power: 91kW at 4000rpm, torque: 272Nm at 2000rpm
    TD42T, 4.2 litre (4169cc) turbo-charged diesel, power: 114kW at 3600rpm, torque: 330Nm at 2000rpm
    Olats talaga ang TD42 kahit na may turbo pa.
    feeling ko lang sa ZD30, kapag hindi pa nag kick-in ang turbo, hindi kaya ang body ng patrol.
    ang hp and torque ng N/A ZD30:
    105hp (78kW) * 3,800rpm
    213 Nm * 2,000rpm
    compare the torque of the N/A TD42 with N/A ZD30, ang layo diba? e mas mabigat pa itong body ng GU patrol.
    Signature
    umakyat kayo dun sa S-bend sa highlands entrance? hehe syet hirap nga nun kung walang bwelo :D
    driven a GU na manual with 35 inch tires, same sa comment ni boybi, pag hindi pag nag fully boost ang turbo parang hindi kaya ng engine. but pag nag boost na ok na.
    anong rpm dumarating yung boost? 2000 rpm?
    parang 2,500rpm ata.
    kapag naka stop ang traffic light then nag go, talo pa ako sa revo sa arangkada, pero after 2nd gear, iwan na sya.
    Signature
    Di ba intercooler turbo na yang ZD30 mo boybi?
    yup, pero as i have said, kapag di pa nag kick in ang turbo, hirap nyang dalhin ang body ng patrol.
    Signature
    hmm... i also have a GU Patrol (auto tranny) but ok naman yung takbo niya since its power (156 hp) and especially its torque (354) is adequate...
    sa arangkada after stoplights, i even outaccelerate gas-powered sedans... it may be that the 4-speed auto tranny is better at acceleration than the 5-speed manual due to its closer gear ratios as well as it being 100 kgs. less in weight...
    as for the boost kicking in, i think it is much lower than 2500 rpm... if that was the case (2500 rpm), then that 354Nm *2000 rpm torque rating should only be 213 Nm (non-turbo) which is incorrect...
    mas mabilis talaga sa arangkada auto trannies, kahit sa ibang vehicles, gas or diesel.
    i might be wrong sa rpm when the turbo kicks in.
    Signature
    tumaas ba ang resale ng patrol dahil tumaas din ang brand new?
    o same lang? boybi, pa test drive patrol mo kapag nandito ka okie
    wala problema boss kimps. kung matuloy kayo sa capas, pwede mo din i-test drive.
    Signature
    pati na rin yung trooper mo. he..he abuso
    basta andito yung trooper, walang problema.
    Signature
    Oct 2003
    ok ata yung ford everest 995k 4x2 1.2M 4x4 mukhang malaki
    Mukhang sulit nga Everest at first glance and for the 1.2M entry price. Pero there's something about the styling i dont like. parang masyadong mahaba for its height...
New Suv'S out!
