pwede kaya cut and add 2 inch dun sa hanger front and back to lift my xto? mas ok kaya ganito project, la kaya maging problem sa differential and propeller? thanks in advance
Fixed hangar shouldn't be cut or welded together to attain the lift that you want, mawawala ang tibay ng bakal. Kahit na lutuin pa sa full weld, inshort delikado.
Sa tingin nyo po ba tama na sa inyo yung height and/or comfort kung walang load? A cheaper option is to extend shackles, another option is to look for a set of leafs to be added with your current stock leaf springs. With enough budget try fitting in aftermarket Fuego leaf springs.
Another option is to attach Add-A-Load device.
yun nga iniisip ko mukhang delikado yun CUT and WELD
pag 4 passenger lang medyo ok pa. actually may generic na shackle na ko kaya lang problem la ko makuha bolt na fit sa rubber bussing. then di ba sasayaw pag extended shackle lang?
sir yun set of leafs mo ba 1 set ng pang fuego or additional molye lang na add to stock spring.
Kung may tingi ng leaf springs much better, since you'll be needing only 2 on each side for additional load.
Di ba kakasya yung orig spring pin sa extended shackle? Para di ka na magbago ng bushing and pins. Kung minimal lang naman ang additional height, I don't think it will have enough side sways.
Originally posted by Ungas Kung may tingi ng leaf springs much better, since you'll be needing only 2 on each side for additional load.
na ka weld yun spring pin sir dun sa oe shackle. pero try ko bumili ng rubber bushing para makahanap ako ng spring pin.
actually sir sa binondo may suplier ng spring recomended by gencars 300 each lang kaya lang di ako maka decide kung alin palalagay ko extended shacle or additional spring na lang.
It will cost less kung additional leaf spring lang. Baka mas mahabang u-bolts lang ang palitan nyo. Kung extended shackles baka di kayanin ng orig shocks ang extension and compression at kailanganin nyo magpalit.
i vote for extended shackles para mas safe in the long run, pero tulad ng sabi ni ungas, kelangan din palit ng shocks para ma-compensate ang additional height
kung mag add ng leaf spring, hindi ba lalong magiging matagtag na yung ride? unless loaded ka parati..
wala bang LSPV (loan sensing propor... valve) ang crosswind?
I checked the website. the added leaf will give you an additional height gain of 1.5" ? mukhang ok ito ah. shackles or add leaf? which will give more height?
ready na yun shackle ko to install problem na lang yun time for installation. nakahanap ako ng 18mm x 5inc na bolt then pina re-thread ko na lang to 16mm para yun shacle sakto lang yun distance para di sya gumagalaw. i hope maging ok na to.
ungas
kayanin pa kya ng oe ko shack or kailangan ko pang mag palit.......huhuhu gastos
what brand pwede ko ipalit?
sensya na mga sirs la ako matutulong dyan kasi la ako alam dyan. dagdag na lang ako tanong. ganyan din ba kasalimuot pag lift ng mga 2 inches sa terrano? :question:
