Ito yung steel or aluminum na parang pa-V or pa-L ang shape na around 1" per side. Mga 1.5ft long lang sana ang kailangan ko.
Balak kong gawing lampstay (via the license plate bolts), eh.
Salamat na lang kung merong may extra.![]()
angle bar 1". kung gusto mo warehouse term it's bar:angle steel 1 inch x 20 ft long hehehe!
sayang sir dami ko dito all sizes, di pwede iuwi.
suggest ko visit your neighborhood junk dealer, or go to a wrought iron fabricator or window grills maker. dami sila nyan, pwede bumili dun per foot. kung gusto mo aluminum go to aguila glass, they'll sell naman to you eh, baka mahingi mo lang nga yan.
sorry can't be of much help, kung pwede lang uwian kita kaso di pwede.
angle bar tawag dyan. pwde ka bumili sa alonzo st., binondo. nagbebenta dun ng tingi. kung gaano kahaba gusto mo, puputulin nila. bilhin mo yung stainless na para mas maganda.
or kung gusto mo aluminum, makakahingi or bili ka din sa mga glass & aluminum shops. sigurado naman meron silang mga retaso.
Signature
that is what i am using for my aux lamps. 1.5" angle bar na heavy duty sost is 60.00 i covered it with benz plates to hide the screws of the lights . i suggest that you also buy a flat bar to put behind the bumper to make it stronger, because if you rely on the plate holes the lights will shake when you hit a bump. i have a bracket behind the bumper connected to the body to make it stronger, befrore i use only the angle bar and the lights would shake and the holes in the bumper were stressed. also you need brackets like the one they use when installing power locks for your plate, because if you bolt your plate directly with the angle bar it will be damaged. IMO will the lights not hit the bumper of your pajero since the plate holes are near the middle, especially if you use big lights, i suggest that you remove the upper bumper ( is that the term) and drill a hole in the lower bumper, and if ever you want to take the out the lights you jsut return the upper bumper and the holes are gone.
I took out the upper bumper already. Nalula ako sa dami ng butas. Yung sa V6 namin apat lang ang butas, eh. Apat na Hella Comets ata ang kelangan ko to fill the holes and may mga matitira pa din. Dalawa lang naman ang meron ako (galing kay kimpOy).
I saw a similar set-up na kasi. Pero medyo olats yung mga ilaw na nilagay.
ARB, pwde bang pa post ng pic nung ginawa mo? tagal ko ng gustong magkabit ng fog lamps. di ko alam kung pano diskartehan.
Signature
Sir Sheep nasa Tandang Sora ako. Pero sa UST ako nag-aaral. San po ba kayo?![]()
di na ako nag aaral ust ka lang pala pwede ko padala sa gf ko from ust sya
ay bakit nabura post ko natira pwede pala yun aheheheh
ulitin ko po meron po ako dito bigay ko na lang po
dyan pa po kayo? yooohooo
09167441180 po sir. Pwede po bang patingin sir? Hehehe. Kung hindi naman sana nakakahiya sa inyo ni Mrs. Sheep.
Kagagaling ko lang po sa kalye. 26" pala yung kailangan niya and mukhang 1.5" dapat. Meron po ba kayo nun sir? How much would it cost kaya?
btw paano ilalagay yun sa bumper i didrill lang directly sa ibabaw? or iipitin sa loob?![]()
hindi kaya ng 1x1" you need 1.5" na heavy duty or 2x2". will try to get a picture and send it to you na lang.
no problem po sir otep meron ako dito dapat kasi gagamitin ko e di ko malaman kung paano mahaba naman po ito :P
Yung isang side naka-rest sa face ng bumper held by the plate bolts. so bale yung isang side magiging perpendicular sa bumper. Yun po ang bubutasin for the foglamps.Paint black ko na lang po siya or chrome.
Hella Comets lang naman po ang ilalagay. Hindi naman siya sobrang laki.
comet 500's. you make na lang a fiberglass na side bumper ala PIAA. may mga fiberglass versions and the they use hella comet 500's
ARB,
Hindi po pwede sakin yung fiberglass side pods. I need the flex that the OEM plastic gives me kasi I usually hit the ground with them (lack of clearance).
Lalong papangit ang apporach angle ko if may lamp. Maganda kasi ang shape nila ngayon because they allow me to slide over stuff.
Yung ganyan ni kcboy basag agad kasisimula pa lang ng off-roading namin dito sa village. Lack of flex and lack of clearance kasi.
ah ok, better use na lang the angle bar. if you can fine 2x3" better you will have enough space for the back of the lights. will try to let wiretap_md get pictures of my lamp stay.
