Results 1 to 5 of 5
August 17th, 2005 10:55 PM #1
hi guyz!
ask ko lang, kung ok lang ba lift ko ung liteace ko, equipped with TEMS, mga 2-3 inches lang..
im worrying baka magkaproblem ako sa performance ng TEMS...pero kung ajust lang ng konti ang T-bar, 2-3inch spacers sa rear coil springs, di kaya mgakakaprob ako nun?
sa mga SUV na may adjustable dampers(local Pajeros, imported toyotas with TEMS, etc), panu nyu ni-lift na di nyu inaalis ung feature na un??
August 18th, 2005 07:51 AM #2
Medyo mataas ang 2-3". That's the max suspension lift of a Pajero already.
Sa Pajero you can keep the adjustable shocks as is kung mga 1-1.5" lang naman ang lift.
Anything more will require new shocks and dis-engagement of the electronic aids. Anyways, a good set of shocks can still perform as well.
August 18th, 2005 09:33 AM #3
4wd kasi un,e..kung sagaririn ko lang ung t-bar, tapos add nalang ako sa ng spacer sa coils na hahabol sa tinaas ng t-bar?
di ko pa gaano nasisilip ang ilalim nito, kung 1.5 inch lang pwede itaas, daanin ko kaya ung 0.5-1 inch sa body, palagayan ko ng spacer between the body and the frame(kung pwede), i assume papalit ako ng brake hoses,etc...
pero sabagay, pwede na ung 1.5.kasi + pa ung pagpalit ko ng tiresize from 195r14 to something a bit bigger (diba may rule for this..) kaya tataas pa ng konti...thanx sir otep,h?kasi ung delica ko 2-2.5 lift with big tires,e...no worries ko dun kasi non-electronic,e...eto kasi electronic,e...
nga pala, may nabibili bang bagong replacement na shocks for my lite ace dito sa atin?mas ok kung map-PM sa aking ung shop.thanx!
August 18th, 2005 04:49 PM #4
Kapag sinagad mo ang t-bar, magiging one-way ang suspension mo. Puro compression, walang extension. Sobrang tagtag niyan. You can try shaving the drop bumpstops to regain travel pero baka ma-force ang angle ng CV joints mo.
Yes, lifts do not come from the suspension alone. Kasama diyan ang added height from the tires.
You can try finding KYB's or other name brand shocks for your van (e.g. OME, XGS, Bilstien) if you search for it on an 'as-per-sample' basis. Generic naman ang shocks niyan. Something is bound to fit.
Tsikot Member Rank 4
- Oct 2004
- 2,315
August 18th, 2005 11:24 PM #5imo, baka sa sobra taas ng lite ace mo e pag lumiko eh tumumba na yan. Lite ace's are not for lifting kasi hindi sturdy ang structure niya
109,606 vehicles were sold in the first quarter of 2024 | TopGear PH
Car Sales Data (2024)
